trafficinsight
In a recent incident I am familiar with the ELT did not go off as it was destroyed on impact. I think in a lot of cases the ELT is only going to be helpful when the crash is survivable...
The Ted Stevens crash was survivable but the elt was either damaged or just separated from its antenna.In a recent incident I am familiar with the ELT did not go off as it was destroyed on impact. I think in a lot of cases the ELT is only going to be helpful when the crash is survivable...
To be honest you don't care all that much if the ELT does't work if everyone's dead.In a recent incident I am familiar with the ELT did not go off as it was destroyed on impact. I think in a lot of cases the ELT is only going to be helpful when the crash is survivable...
True, but the people looking for you probably feel differently.To be honest you don't care all that much if the ELT does't work if everyone's dead.
Doesn't matter unless they really crack down on mounting and installation. Shoot most of them the g switch won't even work unless the cannon plug to the remote switch is plugged in. 406 elts are an ok idea but the execution has been completely bungled imho.Forgive my ignorance, but at what point does the 406Mhz ELT become mandatory?
I like the word "bungled" it makes me happy for no apparent reason. If a connector isn't connected it won't connect. Why aren't the connectors connected?Doesn't matter unless they really crack down on mounting and installation. Shoot most of them the g switch won't even work unless the cannon plug to the remote switch is plugged in. 406 elts are an ok idea but the execution has been completely bungled imho.
Connectors tend to come disconnected when airplanes impact terrain. Especially problematic with the antenna cable.I like the word "bungled" it makes me happy for no apparent reason. If a connector isn't connected it won't connect. Why aren't the connectors connected?
It's been a while because we have our local avionics guy do our 406s but I seem to recall that with most of them unless the cannon plug is in you can't just whack them on the bench and use a stereo even for the 121.5 portion. I think at least for the Artex ones you have to have the remote switch as that is one way you do the self test on it.G-switch should still work as long as the ELT is armed... The remote switch isn't even mandatory is it?
Yes.So roger, you'd recommend a 406 PLB before dropping the cash on a 406 ELT?
Why you gotta make fun of my landings? I already get called a "retard" twice as I enter the flare.
