still dont get it...I understand aerodynamics but I am just sitting here picturing an airplane at full throttle on a treadmill with zero forward motion. If those wheels are going a thousand miles per hour it makes no difference providing there is no relative airflow over the wings to make the plane fly.
I do understand how the wheels work and that they are just free on bearings and not mechanically driven. I should probably stop posting because I think what I am envisioning is not what we are talking about here and I am making myself look stupid
One more try here...you're completly correct that if the plane were "held back", no way it can take off. But, if you're thinking the plane would be "held back" by the interaction of the tires with the treadmill, try to conceive exactly how that would happen.
Remember, rotating the free-spinning tires using an external force (i.e. treadmill) acting on the tread does not affect the position of the axle.
If you rotate a tire by applying torque to the wheel, the way a car works, the tread is coupled to the road/treadmill by friction, and a shear force is applied parallel to the surface. Think of the "bottom" tread as "pushing backwards" against the road/treadmill if you like. The required equal and opposite reaction is the axle (and thus the car) moving forward.
When the wheel is free-spinning, the equal and opposite reaction to the "bottom" tread motion is the opposite direction motion of the "top" tread as the wheel rotates. No net force is applied to the axle, except for a small amount attributable to friction in the bearings.
Here's another analogy. Load your light aircraft of choice on a flatbed truck with no tailgate. Leave the brakes off and don't chock it or tie it down.
1. Drive the truck away veeerrrry gently and slowly. What happens?
2. Drive the truck away with normal acceleration. What happens?
