NovemberEcho
Dergs favorite member
I am out now, if i get ahold of the aim I'll look up the reference, otherwise ill necropost in the winter on recurrent.
Enough of this monkeying around
Just to be extremely clear, lets say we're talking the ILS 31L at JFK. The missed approach instructions on the plate are climb to 500ft then climbing left turn to 3000, intercepting the JFK-190 outbound to Chant.I agree. We're still gonna fly straight and clean up the aircraft while the non fly tries again.
If this is simply for the purposes of being clear, option above. And if you mean well past meaning i finally got ahold of them at 800ft, then even easier for me to swing the knob since I'll have the auto on too.You are at DH, you go missed and tell the tower you're missed to no immediate response, you have been instructed by your company and you are going to climb straight ahead well past 500 feet(only a few seconds after going missed) and not turn, awaiting ATC instructions correct?
Why can't you? Have TEB put in their LOA with you to issue some heading/altitude that doesn't conflict with the 22L arrivals.To give another example, the best approach we have at TEB is the RNAV 19. But we can't use it because the published missed puts you right in the EWR 22L final. We can't create some LOA with TEB tower with alternate missed approach instructions.
The purpose of a published missed approach segment to a towered airport is a contingent for a NORDO situation. This way the pilot does not do anything to surprise controllers. An LOA with TEB would not be good enough, the published missed should be changed if it conflicts with other traffic and it sounds like a good ATSAP candidate to me.Why can't you? Have TEB put in their LOA with you to issue some heading/altitude that doesn't conflict with the 22L arrivals.
It's included in the LOA with towers underlying my approach to issue runway heading in the event of unplanned go-arounds. It's not the heading I'd have picked, because they'll be in Mexican airspace in 2 miles off one airport and 5 miles off the other, but that's the default they'll issue unless I tell them something else.
Depends....some of the approaches I work have the instruction on the published missed to fly a heading and then expect radar vectors. That's tough to do when you're NORDO.The purpose of a published missed approach segment to a towered airport is a contingent for a NORDO situation.
Is there a way to add a stepdown fix after passing TEB on the 22L approach? We did that at CRP to run 31 approaches over top of NGW (shrinking their delegated airspace to 1.5 mile radius and 800 feet.) NGW doesn't have any IFR approaches, so it's a little different.The 22L arrivals are descending to 2500 directly overtop rwy 19 at TEB. The MVA is 1800. We can't just assign headings and altitudes below the MVA, especially in weather that would make us want to use the GPS19 because it has lower mins than the ILS 19
We've got 7 of them at one airport that include radar vectors on the published missed.Yep and it is not safe, when our VOR is out they publish a NOTAM for /A aircraft to fly runway heading and maintain 3000. If it ever goes like that long term I will ATSAP it every day we are IFR until they fix it.
Ask a civilian pilot what they would do if the publish missed included radar vectors.We've got 7 of them at one airport that include radar vectors on the published missed.
Plus the PAR/ASR approaches where if they go lost comms and can't maintain VFR, they proceed direct to an IAF to conduct an instrument approach of the pilot's choice.
Roll inverted and pull.Ask a civilian pilot what they would do if the publish missed included radar vectors.
