Malaysia Airlines 777 missing
Doubtful. Both Newark and Detroit were outside its fuel range capabilities.
Pretty much, but they also include the ship's radar feed, which is all primary returns. Remember, unlike us, ships use the radars for TRAFFIC avoidance, so there is a good chance they would pick up any primary returns off the aircraft in the area also.
I didn't know that they recorded their radar feeds, but if that's the case, that could certainly be useful in this instance.
If the 777 was a surface ship or low-level flying the ocean surface, sure.
Worth checking, but very doubtful it would turn up anything.
I don't know if it's even worth checking unless this drags out far longer than it has. My understanding of radar is fairly limited, I confess, but to my knowledge you don't aim nautical radar high for many reasons... mostly to avoid error. Its purpose is short range traffic and obstacle detection, not aerial surveillance... and given the shape of the earth, propagation phenomena and other pertinent issues, I can't help but think that, based on my limited knowledge of the subject, it would be rather silly indeed to try to take that angle.
Of course, I could be mistaken. I've never crewed a vessel with radar.
-Fox
-Fox
Agree. Very doubtful it would turn up anything remotely useful. It is short range, and surface or very low aircraft primary returns. And like you say, surface only; there's no aerial surveillance being done as would be done on a combat ship such as a destroyer/cruiser/frigate etc, with their target tracking radars and such.
The only reason I say "potentially worth checking", is simply due to the complete absence of anything else at this point, and to truly leave no stone unturned, if it's possible to get this information.
Ships mostly use X and S band radar sets that generally don't point up more than a few degrees. They wouldn't capture anything air born above 500 to 1000 feet. Even if a dish happened to pointing in the correct direction at the moment that a plane (hypothetically) descended (fell) through the beam you'd only get a return for one sweep and as such it would be disregarded.
Of more use would be a SONAR feed. Who knows if we or any other countries have any assets placed out there that may have heard an impact and breakup noises. It's shallow water, which can play hell with acoustic signals.
Ships mostly use X and S band radar sets that generally don't point up more than a few degrees. They wouldn't capture anything air born above 500 to 1000 feet. Even if a dish happened to pointing in the correct direction at the moment that a plane (hypothetically) descended (fell) through the beam you'd only get a return for one sweep and as such it would be disregarded. .
That's what I was inferring, that anything that might have been seen by a surface radar for a quick sweep as it's falling through, and considering its short range, likely would've been seen visually by lookouts, assuming clear visibility.
IMS, SOSUS proved to be far more effective than expected, picking up soviet subs thousands of miles away....in the 60s. With the advances in sensors since then, I'd be surprised if there wasn't usable data. Whether such a thing would be released publicly is a very different question. The area where this occurred is er..."sensitive".
I am far (far, far far) from being an acoustic engineer but I don't think something like a SOSUS line would work in water as shallow as the South China Sea. That said, with the amount of... activity going on there recently I wouldn't be surprised if we had a sub or two in place out there already who may have heard something.
Can anyone explain the cellphone thing? I find that weird...I've only known dead/destroyed cell phones to go to voicemail thus far.
Crazy how far off the debris field is..
Best point I have seen to this time from CNN:
The investigation of Malaysia Airlines Flight 370 will be sure to take many months, if not years. We will know the truth of what happened when the aircraft is found and the recorders and wreckage are analyzed. In the meantime, speculation is often inaccurate and unproductive.
