JPVilla62
ClearedToThe said:I can't believe this thread is 3 pages long already...
If ATC say's "maintain X,000ft until established" and you are not at X,000 ft, then you descend to X,000 ft and join the localizer. Once on the localizer descend as appropriate...
AIM
5-5-4. Instrument Approach
a. Pilot.
3. Upon receipt of an approach clearance while on an unpublished route or being radar vectored:
(b) Maintains the last assigned altitude until established on a segment of a published route or IAP, at which time published altitudes apply.
These PUBLISHED ALTITUDES can either be a MINIMUM altitude (as 99% of them are), or they can be a MANDATORY altitude. If it is a MINMUM altitude, you do not have to descend down to it because it is a...MINIMUM...not a mandatory altitude. Step down "manually" if you want to do more work than necessary, or stay at the last assigned altitude and ride the GS down and monitor your altitude to ensure you don't descend below the...minimum...altitudes along the localizer.
I agree. I said that on page two.
