A Life Aloft
Just some fun history.........
A Los Angeles Airways Sikorsky S-51 helicopter takes off from the roof of the Terminal Annex Post Office, 1 October 1947. The Los Angeles Times published this photograph 2 October 1947 with the following caption: “NEW MAIL SERVICE — Los Angeles Airways helicopter shown landing on the roof of Terminal Annex Post office yesterday to inaugurate helicopter air-mail service, the first of its kind in the United States. Two flights daily are planned on this run with another to start Oct. 16.”
1 October 1947: Los Angeles Airways began regularly scheduled air mail service in Los Angeles, using the Sikorsky S-51 helicopter.
“. . . the U.S. Civil Aeronautics Board awarded LAA the route authorities to operate local air mail services in Southern California using the Sikorsky S-51. Before long, LAA was operating a twice-a-day mail service between the main downtown post office and Los Angeles International Airport along with a small package air express service.
“With a fleet of five S-51s, LAA’s first year of operations resulted in 700 tons of mail being carried with approximately 40,000 landings throughout the Los Angeles metropolitan area. The small operation maintained a 95% reliability rate and by the time it began its small package air express service in 1953, it was annually moving nearly 4,000 tons of mail a year.
“In July 1951 the CAB awarded LAA’s reliable helicopter operation the rights for passenger services which started in November 1954 with larger Sikorsky S-55 helicopters while the smaller S-51s continued the mail and small package services.”
The S-51 was a commercial version of the Sikorsky R-5 series of military helicopters. It was a four-place, single-engine helicopter, operated by one pilot. The cabin was built of aluminum with Plexiglas windows. The fuselage was built of plastic-impregnated plywood, and the tail boom was wood monocoque construction. The main rotor consisted of three fully-articulated blades built of metal spars and plywood ribs and covered with two layers of fabric. (All metal blades soon became available.) The three bladed semi-articulated tail rotor was built of laminated wood. The main rotor turned counter-clockwise, as seen from above. (The advancing blade is on the helicopter’s right.) The tail rotor was mounted on the helicopter’s left side in a pusher configuration. It turned clockwise as seen from the helicopter’s left.
The helicopter’s fuselage was 41 feet, 7.5 inches (12.687 meters) long. The main rotor had a diameter of 48 feet (14.630 meters) and tail rotor diameter was 8 feet, 5 inches (2.565 meters), giving the helicopter an overall length of 57 feet, 1 inch (17.399 meters). It was 13 feet, 1.5 inches (4.001 meters) high. The landing gear tread was 12 feet (3.7 meters). The S-51 had an empty weight of 4,050 pounds (1,837 kilograms) and maximum takeoff weight of 5,500 pounds (2,495 kilograms). Fuel capacity was 100 gallons (378.5 liters).
The helicopter was powered by an air-cooled, supercharged, 986.749-cubic-inch-displacement (16.170 liter) Pratt & Whitney Wasp Jr. T1B4 (R-985 AN-5) direct-drive, nine-cylinder radial engine which was placed vertically in the fuselage behind the crew compartment. This engine was rated at 450 horsepower at 2,300 r.p.m., Standard Day at Sea Level. The R-985 AN-5 was 48.00 inches (1.219 meters) long, 46.25 inches (1.175 meters) in diameter and weighed 684 pounds (310.3 kilograms) with a magnesium crankcase.
The S-51 had a maximum speed (Vne) of 107 knots (123.1 miles per hour/198.2 kilometers per hour). Range was 275 miles (442.6 kilometers). The service ceiling was 14,800 feet (4,511 meters). The absolute hover ceiling was 3,000 feet (914.4 meters).
Of 220 helicopters in the S-51 series built by Sikorsky, 55 were commercial models.
At SNA
1959 LAX
In 1962 Los Angeles Airways were the first carrier in the world to put the large S-61 into scheduled service. This was the first helicopter to have the cabin formatted like a pax fixed wing aircraft. It could carry 28 passengers at a cruising speed of some 140 mph.
At the Disneyland heliport
Igor Sikorsky
At SNA
1959 LAX
Igor Sikorsky
