Flyin_bryan
Ive had this in my mind for a while, Im not sure if I broke a rule, but I think the circumstances dictated it.
SETUP: On a VOR instrument approach that is not aligned with the runway in actual at Fullerton airport in california. Im instrument rated and sitting in the right seat, a guy who is not an instrument student nor instrument rated in the left seat. We are flying a low wing airplane that has a big nose on it, hence there is really restricted visibility to the ground from the airplane, especially at low airspeeds when the nose is up. Weather just above minimums. Landing runway 24.
here is the approach in pdf.
WHAT HAPPENED: Were coming up to Fullerton airport and I realize I cant see #### out the front or left of the airplane because of the restricted visibility outside from the wings/nose of the aircraft and the guy sitting in the left seat blocking my view. The airport is so small you really have to fly to the right or left of the airport to see it from this particular airplane (you cant see right below the aircraft). The non intrument pilot in the left seat should be the first one to spot the airport becase of how this approach is angled. However, he donest know what the heck is going on and doesnt call out the airport. We broke out of the clouds just above minimums, 1 mile before the MAP.
About 2 miles from the airport I switch over to tower, tower comes back cleared to land and says make left traffic.
Mind you, I wasnt told to expect left traffic, and it does not say left traffic anywhere on the approach.
By the time I visually identify the airport, we are over it, and then slightly past it. I tell the tower Im making right traffic, contrary to what he had said, and I dont have time to ask or explain.
The reasons I tell him this is becuase if I turn to go make left traffic now I will lose sight of the airport under the airplane, and I cannot see out the left side of the airplane very well with the other guy sitting there. If I make right traffic from the current position, I can clearly see the airport throughout my downwind leg, base leg, and final. I elected it was safer to make right traffic.
We landed no problems.
One factor why they make left traffic might be a couple low towers on the right traffic. I was aware of this on the approach and made a tight right hand traffic pattern.
We used the radar minimums.
The approach does not dictate left/right traffic.
Was this the correct thing to do / legal thing to do?
