Lear down in PHL
I agree. If you’re a jet carrying hospital patients, yeah I think it ought to have operable FDR and CVR.
I don't know if it's necessarily hospital patients that warrant a FDR/CVR. I don't see them any differently vs a paying customer.
But something that's turbine...requiring type ratings...multiple pilots.....that presumably will be used in business or as a business....over 12,500lbs...Costing millions of dollars. All these little things summed in my mind say it should have the same level of equipment as we'd expect from say an airliner. I'm sure the paying customer expects it, and the public at large should expect it.
We’re talking about a multi million dollar jet , not some 172. Things are gonna get pricy, that’s the cost of going 600mph at 40,000’.
And when things go wrong , a lot of people can get hurt…
I agree that it would be beneficial, but in this case - the hull value of a clapped out Learjet is probably lower than the avionics installation.
Just a couple years ago ADS-B installs were very expensive for some operators with vintage equipment. The lists of STCs for a FDR/CVR that would be compatible with whatever legacy avionics are installed in that make/model is going to be quite short.
Yeah, requiring new tech on new aircraft going forward is a different ball game than requiring retrofits.
ETA: post edited, see post #110 below…
They can comply with regulations or not fly the things — just like everyone else.
A quick search for FDR requirements yielded this (there’s probably better info out there…):
Example (more in the link):
No argument here, just pointing out to the Monday morning quarterbacks that some things are easier said than done.
It’ll take me a minute to research it, maybe someone else has it readily available, was this required to have these items based on nation of registration, operational requirements, ICAO, applicable MEL, etc.
The CVR not working for "years" is kind of telling me where this investigation is heading...
The regs can require all the equipment they want, but it still has actually be maintained in working order. I doubt they can do anything to the folks that pencil whipped the inspection of th CVR, since it's a foreign registered aircraft and the mechanics most likely doesn't work in the US.
From what I understood the company didn't pencil whip the CVR inspection, it just wasn't required to be operational.
How does that work with a foreign operator are they subject to the same requirement the FAA states since they’re operating our airspace or international ICAO regulations, not aware of Mexican authority so I just assume it’s under ICAO
Ideally, it should be installed during manufacture.
All of the jets (US registered) that were equipped with a CVR that I've worked on required a fairly extensive functional check. I can't recall if it's an annual or semi-annual requirement, but you have to test all of the audio sources (the microphones mounted in the cockpit, any headsets, and anything the audio panel might provide including HF) and you have to do it with the airplane with no engines running, with the APU running, with each engine running by itself with no APU, with each engine running by itself with the APU and both engines running with and without the APU. I've seen airplanes come into a hangar for big inspections and somehow halfway through the inspection when the airplane is still on jacks that workcard is somehow miraculously signed off as completed. I'm quite certain the portion that didn't require running the engines was completed, but I'm also quite certain they never actually finished the scope of the functional test. I get why it's done but it's one of the reasons why I walked away from the whole shebang.
This absolutely doesn’t surprise me considering the type of operation. My experience in 91/135 (which is most of it so far, just started 121) is one of habitual noncompliance with various regulations and industry best practices across the board. I realize this is a foreign tail, but there is a reason why these types of operations have incidents/accidents at far greater rates than 121.
It’s almost like corpies WANT to corp.
