Landing without a Landing Clearance
The reasons why a landing clearance is not given on initial contact with the tower are many. Often a "continue" or "expect landing clearance short final" are given but not always. If by a 3 mile final your still waiting, ask. If its too busy and you can't get a word in edgewise. Go around, its what is expected. Period.
Minimum fuel- You get no priority for stating that. Read the AIM for the agreed definition we all use.. What's min fuel to you is likely to be different from the next pilot. If your running a sequence and the only option to change your # is to break someone out, the controller is not justified in doing that and most likely will not be supported by management and whoever got broke out will likely call and complain. "Emergency fuel" will get you priority and other a/c will take a lap to get you what you need.
High horse much?
Everybody and their dog skip knows that landing without a clearance breaks the FARs. Some of us prefer to give real world examples rather than coming in here and screaming DOOOOOOOOMMM!1111oneone
This has nothing to do with the high horse.
My point was just that no one on here has given any good reason to land without a clearance, putting your certificates and lives of hundreds of passengers on the line. I also think I gave a couple good real world examples:
1) Unsure whether or not the guy holding short downfield is actually holding short.
2) The FAA questioning you and you saying "I was just trying to help the controller out".
Both of the above are VERY feasible.
After landing in ORD without a landing clearance because the frequency was so congested everyone was stepping on each other and then taxiing nearly all the way to the ramp entrance without a clearance from ground because that one was congested as well and you NEVER stop on a taxiway in Chicago unless you're going to hit something or you are told to, "Eagle XXXX, Nice job. Tower says 'thanks, you're cleared to land' . You know where you're going. Continue taxi to the ramp. We are really having one of those days up here. Take care."
Wow, no violation. I wonder why not? And why would the tower have thanked him for landing? Why would my 20 year captain, based in ORD nearly his entire career, have risked his job? Maybe he knew something I didn't know....
What about landing on 21L in DTW when they're shooting departures off 22L DIRECTLY in the path of an unannounced (can't get a word in edge-wise on ANY of the tower frequencies) go-around?
Pick your poison - declare an emergency, go around and get an RA, or visually sweep the runway with your eyes/TCAS, and file an ASAP immediately after touchdown.
I have seen all three, but wasn't in the cockpit - going to withhold judgement.
Clear as mud?
Rumor has it that ATL presumes "you see the green light"
That's the rumor I've heard, and logic would say if you're #1 on final in a place in ATL they know you're coming.
That being said its not good enough for me. You'll never have to do a carpet dance for a go around without a clearance, but you might for a landing without a clearance. Not worth it to me.
Besides, I could use the practice.
No clearance landings happen all the time. ATC/Pilots forget. They should make the rules so that you're only cleared to land when you're number1 with a clear runway like in Europe.
Hah, I hear a lot of "Number 4, behind medflight air taxi, banner tow, cessna on 2 mile base....Cleared to Land."
You can always get "landing clearance revoked" if it ain't gonna work out :)
This happened to me in EWR one night. On final we check in. Told to continue. "500 ft" "checks on glide"...ok we cleared to land?....wait no we are not. "200" still cant get a word in. Tower guy is slammed with all the evening heavy departures and longwinded readbacks by other aircraft. So, 100 feet and we are outta there. I had the departing BA 777 insight and made a turn to parallel his DP course(190 hdg). The controller freaked then asked the reason for the go around. We responded..."no landing clearance". Silence.......so yeah we were in the right. But had we landed no one would've probably said a thing since he was oblivious to the fact he never cleared us. Regardless the go around is the textbook answer since we were never really sure why he told us to continue. Could've been an ops vehicle, another aircraft disabled....who knows.
He probably had someone in position and hold when you checked on and just forgot to clear you to land after clear that aircraft for departure. Thanks to the great, great TIPH rules at a ton of airports across the country.
