The reasons why a landing clearance is not given on initial contact with the tower are many. Often a "continue" or "expect landing clearance short final" are given but not always. If by a 3 mile final your still waiting, ask. If its too busy and you can't get a word in edgewise. Go around, its what is expected. Period.
Minimum fuel- You get no priority for stating that. Read the AIM for the agreed definition we all use.. What's min fuel to you is likely to be different from the next pilot. If your running a sequence and the only option to change your # is to break someone out, the controller is not justified in doing that and most likely will not be supported by management and whoever got broke out will likely call and complain. "Emergency fuel" will get you priority and other a/c will take a lap to get you what you need.
