JAA Private to FAA Private Conversion: Night Flying?
Blackhawk;1131666From chapter 21 of 8710.3E [I said:
(4) [/i][FONT=Times New Roman,Times New Roman][FONT=Times New Roman,Times New Roman]Some foreign-pilot licenses contain a restriction that prohibits the person from operating an aircraft at night. As an example, some foreign CAAs require their citizens to hold an instrument rating and/or a night flying privilege in order to operate an aircraft at night. That person must also comply with that night operating restriction of their foreign-pilot license when exercising the privileges of their § 61.75 pilot certificate (see § 61.75(e)(3)). A point of clarification: the FAA may not remove the night flying restriction. It is permissible for a foreign pilot who receives a U.S. pilot certificate based on his or her foreign-pilot license to accomplish the required night flying training (for the appropriate grade level of U.S. pilot certificate held) from a holder of an FAA flight instructor certificate, and to receive a solo endorsement to exercise night flying privileges on his or her U.S. pilot certificate. [/FONT][/FONT]
Isn't that what I said?
He can in fact sit for the CMEL (full fledged) but from what I understand his JAA Certificate will always be the basis (in fact his FAA ticket will read: Valid only if accompanied by FPC # Blahblah)
The goal must be to lift and remove limitations from his JAA Cert from being transferred onto the FAA Certs..
Can a DPE combine a PPMEL & a CPMEL to assure that the CPMEL is no longer based on the limited foreign cert?
He does not have to give up his FAA PP.
Also, if he meets the requirements for a CMEL, there is no need for him to take the PMEL check ride. He can just skip the PMEL and go straight to the CMEL (stand alone); again, as long as he meets the requirements.
Makes sense.
Isn't this initial FAA certificate a validated (authorized) JAA license?
The only way I had in 99 to get a "unlimited FAA PPSEL" was to get the training, sit for the written, oral and flight test. I assume this could be intergrated into his FAA CPMEL. I'd also consider the issues with getting the limitations removed from his JAA ticket once he comes back.
He/She can obtain authorization under JAA to fly at night, based on FAA credentials. Just thinking doing it right could be quite beneficial...
If not - he is turning in his validated license when being issued his FAA CPMEL. Then it is important to make sure no limitations land on the FAA ticket. All it takes is some ding dong in Oh Oh City to miss one checkmark in IACRA...
I'd still (even though it looks clear like a million) want to talk to the FSDO & DPE to have everyone in the same boat. Something doesn't look right because there is no full fledged certificate being attained, other than meeting experience requirements and training on a validation...
Makes sense.
I'll have to look, but I don't think he has to turn in his JAA/FAA certificate when issued his stand alone FAA certificate. At least that has been the case in the past with students I have dealt with. I don't know if this is a local interpretation that is incorrect, however, so I'll have to look into it.
