I always call mileage from the field, even in solid IMC. That way you get into a habit of using the same type of position announcements and feel comfortable making them in VMC or IMC.
See I disagree with that because if there are other traffic in the clouds with you they're going to scrambling to figure out what the heck you are. Use known reporting points and fixes and don't make up your own.
Maybe, maybe not. Again, it likely depends on who you're dealing with. Calling DME shouldn't be too bad since other's should be able to look at the plate and see the DME associated with the fixes, pending they call a DME that's printed on the plate associated with a fix. But I do see your point.
