Every plane I fly (annoyingly) seems to always have an expired gps database. I've been told you can supposedly file /G as long as you verify all the procedures are correct and havent been changed, but how are you going to realistically do this without climbing in the airplane and loading up every approach you might potentially use. I believe the same rule applies to filing /A and using it for DME. So is filing /U the correct way to go about it? It seems kind of pointless when you have the GPS and probably creates more work for thr controllers, but I don't want to get violated or worse.
