The plane tells you if you have ice or not?
I think the ERJ turns on the anti ice automatically. The CRJ has to have the switches thrown manually. We've got an ice detector on both sides of the nose. It's basically a little rubber nub that vibrates in the slipstream. If the vibration changes a set amount due to ice accumulation it will trigger an ice alert. It then heats itself to melt of any ice that may have formed and then starts monitoring for a change in vibration frequency again. Pretty nifty design actually.
Fancy!
We look out the window...
Fancy!
I am going to aviation purgatory for correcting people with more experience but....
Rosemont probe = TAT probe
and I didn't know the Ice Detector Probe had any rubber..... I'm pretty sure it doesn't.
Awww, why not? I don't consider any ground lesson addressing icing to be complete if I have not hummed the first few bars of that song to help jog the student's memory.No. Just no.
I think Rosemont is a manufacturer. A TAT probe is a product, just like the Ice Detector.
I prolly shouldn't have used the term "Rosemont probe"
Clearly you have grasped the fundamentals of CRM
In the saab its OAT, and then just plane looking outside at the wing, and the prop hub to see how close its getting to the painted on line.
And if you're lucky the engine anti-ice wont fail.
Problem in the CRJ is you can't see much of the wing. Best place to look is on the wiper blade attachment nut and the base of the wipers. You can also see a little bit of the outboard section of the wing, but when you are flying in reduced visibility it's hard to tell if there is anything out there.
Dont forget several flights were doomed due to ice.
SAS Flight 751 in December of 1991
Air Florida Flight 90 in January of 1982
American Eagle Flight 4184 in October of 1994
Continental Airlines Flight 1713 in November 1987
And US Air Flight 405 in March of 1992
Ice is nothing to underestimate. It is a quiet killer. Pilots, please be careful and never assume that your instruments are telling you the complete story. Its better to error on the side of safety that to have your aircraft upset without the ability to regain control.
Safe flying to all. :rawk:
