I hate grounding airplanes!!!!
Douglas
Old School KSUX
I don't know about you guys but when I ground planes and cancel flights I get upset.
You do it because it is the safe thing to do.
and I always hate having to walk up to the mechanics and say, "It's acting funny".
Is it ever simple....NO..."what's wrong with it?" "It's broke".
It can never be that simple, instead, "I kind of had a bad mag check and the throttle was pulling itself forward, oh and the engine was rough".
All the while the mechanic is thinking, 'I will just let it heal over night.'
Then I come home and get on the internet and rant...
I guess I'm just tired of guessing when a plane needs to be ground and having the mechanic come back and say, "we found nothing wrong with it".
Anybody else get anxious when they ground an airplane?
(by the way, we we have three great mechanics that work for our school, I am not slamming them in anyway)
I have never ever written anything up...in my 140 hours of flying.
Today I took up an airplane and someone wrote "Gyro precesses 180 degrees in 5 minutes" hahaha who needs a heading indicator anyway.
I had a couple issues with sparks plugs, gyros doing donuts, high oil pressure, and weather issues. It happens and I guarantee this will happen again as long as you fly, so just get used to it.
Why worry about it? The mechanics are there to do one thing. Fix things. Not only that but if you start getting comfortable with engine roughness and rough mags its only a matter of time before you lose your engine mid-air. Don't feel bad, you're being safe.
The first couple times I grounded the Twinstar, I felt bad about it. Then it shut an engine down on me in flight. No more feeling bad. Instead I go kick it.
Eh... if it's broke, write it up. I'd much rather have someone's canceled flight on my conscience than their in-flight emergency.
What bugs me is when maintenance can't duplicate a situation on the ground and is all pissy at me. "Yes, the CB popped twice in flight. No, I did not imagine it. What was I doing? Straight-and-level." They glare at me and return-to-service it goes. Sheesh. I'm not writing up planes just because I can't get enough of our mechanics' sunny dispositions.
Ooh... or one of my all-time favorite write-ups: a school I was at had an airplane whose stall warning horn wouldn't activate in-flight, but would ground check just fine. So in my write-up I note: "...inop in flight; ground checks okay." The corrective action? A photocopy of POH pages explaining how to ground check the horn and a comment that, indeed, the horn ground checks perfectly. :banghead: A couple write-ups and a hundred hour later, they find the horn was miswired. :bandit:
Easy way to fix this problem:
Don't stall!
What is this stupid 'seat of the pants flying' anyways???
And it's soooo dangerous anyways, and the student doesn't have to know this. Maybe the DPE won't stall for being afraid of it him/herself?
When the equipment gets smarter than the guy repairing it, it's time to get the tools out, take the spinner off, and remove the prop. Take it home, and offer to bring it back after the rest of the plane is safe...
Last time I checked it took three days or more to get a composite prop replaced. Is that enough time to get the airplane up to par? :D:D
welcome to aviation... it doesnt get any easier. I always hate avionics problems because sometimes it would "check out" fine when the mechs looked at it, but the problem persisted intermittently in the air...
Fouled plugs?? You have a checklist for that? Today I almost had to ground my plane. We planned an instrument flight, departed with 4sm br ovc007 wanted my student to experience all that good stuff and headed to good ole' ACY. Kicked the fires and lit the tires, and the RPM gauge for #2 goes all wacky. Decide to see what happens on run-up and the guage finally stabalized and stayed that way for a good 10min prior to departing as a precaution. All the time I was thinking... My frickn luck! Took off with no anomalies everything went smooth after that. Came in for a ILS C2L. All in a days work. :bandit:
I told this story here once before but it kind of fits with this thread.
We had a blower go out on one of the Ag Cats one day and called the shop to come fix it. We were in the busy season and needed the plane working. The owner gave the shop people the N# and told them that there would be two Cats parked together nose to tail. Now, to change the blower, you have to pull the engine. After giving the shop the info on the broken plane, everybody went home. I stayed in a trailer at the strip throughout the season. I went to bed and the mechanics pulled in late that night.
Next morning I looked out the window and I thought they had swapped the planes around for some reason. Nope, they pulled the wrong engine. The boss wasn't happy when he got there. Took the poor guys several more hours to get the good engine back on and then they started on the bad engine.
This thread just made me think of this.
Don't feel bad about grounding a plane.
I had a friend that "thought" he was hearing a popping sound in the fuselage for a couple of days. Took off and the wing snapped.
Don't mess around with safety. Get it checked.
i have seen the gyro donut too! i also am curious if you went to school at the UND campus in spokane? if so what was the tail number of the plane that had the goofy gyrpo (i am curious if i have flown it before)
I was on a x/c with a student from our University. We went to do our runup and had a rough mag check. I tried everything I could think of..letting it cool down and looking for a cold cylinder, get it as hot as I could, etc. Nothing. We had to get picked up from one of the linemen. It was about a 2 hour drive both ways.
Found out the next morning that it was a very fouled plug, no burning it out. Ran great on both, but not so good on the right side. I wasn't about to take off and let my student think that was ok. I feel your pain!!
p.s. On the bright side, I got some free flight time in the boss's 421 when he took me to pick it up!
Really? I fly a plane that is well maintained and only 6 years old, and I've had to write it up several times for various stuff. But I'll hand it to the schools Mechanics, everything is always signed off by the next time I fly.
Nobody who professionally flies an aircraft should EVER feel a twitch of guilt about writing up a maintenance discrepancy on an aircraft.
If it isn't written up, it won't get fixed.
How would you feel if you ignored something that you thought was "no big deal", and then found out that item's failure contributed to someone planting themselves into the ground?
Can't tell you how many times I've sent the same ac back to mx because the mx guys couldn't duplicate the issue.
I just keep writing it up until it's fixed. And ultimately mgmt can see that it is a loosing proposition to try to return it to service when it just gets squawked again and they don't make money
:yeahthat: Grounded that plane lots.
I kind of like the rolling eyes and occasional confrontation from managers/owners when grounding something. I grounded a DA20 once (the day after an engine of another DA20 quit running during a steep spiral (yes, I was clearing the engine)) because it didn't pass an idle check after my run-up. Maintenance came, got the plane, moved it to another location and a few weeks later it crashed short of the runway during a power-off 180 (everybody's OK). They probably should have looked at that one a lil closer...
I did go to the UND campus in Spokane, but it wasn't there. In fact I never had any problems with their airplanes. When I was instructing in Tulsa I think it was N17RR, I can't remember they had almost 30 C152's
The avionics shop we take our planes to is great for analog, but totally clueless when it comes to glass--which now makes up fully half of our fleet. It seems like every time we drop a G1000 off up there, they fix one problem while causing three more. And then, of course, the shop points their finger at Garmin, who blames Diamond, who accuses the shop and so forth. Meanwhile, our plane which just needed a software update is down for two weeks.
I take notes durring every flight and note anything that is acting up. I then give that to MX, so they can decide what to do about it. If I don't tell them what is wrong, how else will they know?
I usually don't write up any of this stuff in the logbook, unless it's a serious issue.
