I'm sure you could get the nav light changed real quick like if you told the mechanics the situation
What if there is no mechanic? Make it you're in the middle of nowhere.
That's the whole point, they want to get you out of your bubble. They will have an MEL for nav lights and they sure as hell will have a snow plower to move airplanes out of the hangar, that's not the point. It's about theory, there is no right or wrong answer, just the answer that they like. They are in the business of saving lives. It's a little cold to say I'm not going to save that life because of a burnt light that will violate regs, eventough it's a correct answer in an airline interview, it may not be for them. The next question they will ask you is; so you're ok with the person dying because of a burnt light?
2) Use the 4X4 to clear the snow, then use the tug.
All three questions are asking you to balance customer service against protecting company assets. I'm guessing the company is more interested in its assets. Otherwise company policy would read "Do what you need to do to get er done."
3) You are 20 minutes from your destination when the chip detector detects a chip in the left engine which causes you to shut down the engine. Do you continue to your destination with the patient, or do you divert immediately to the airport with 10 miles that can handle your aircraft?
I would not be shutting down a perfectly fine engine over a chip light in the first place.
even if that means completely annihilating your career?
Yeah that is why I said I wouldn't fly with it.
I am the pilot, not the administrator.
I'm not going to get hired at some place and then start breaking the rules in their airplane.
I don't care what is in the back -- flowers, critically ill patients, it is all superfluous information.
Since it is company policy to only use the tug and nothing else, I'd call the company.
"Hi -- I'm here with the plane and the taxiway is plowed enough to use and the runway should be plowed enough for me to takeoff in a few minutes. I can't get the tug to work in the snow here at the hangar. We can't do this mission unless I can use the 4x4, but that's against the rule of using the tug and nothing else. Would you like me to cancel this flight, or try using the 4x4?"
If they want to waive their own rule then that is their prerogative. If they say no to changing the rule, then there is no decision to even be made -- the plane is stuck.
These questions were asked of someone close to me in a recent interview with a Fixed Wing Air Ambulance Company. How would you guys answer these questions:
1) You preflight the aircraft and notice that one nav light is inop. The nav lights are not on the MEL and are required for the flight. Would you still take the flight to move the critical patient?
2) You arrive to pull the aircraft out of the hangar and there has just been a heavy snow fall. The tug (which is the only approved vehicle to move the aircraft) cannot operate in such heavy snow. But you do have access to a 4x4 truck. Do you go against company policy and use the 4x4 or do your scrub the mission to move the critically ill patient?
I know how I would answer these (which was similar to how the person answered them in the interview; the person did not come away with a good feeling from the interview). How would you answer these questions?
Lol, then you're not going to get the job. It's amazing how people take interviews as a matter of fact. It's a game. There is a difference in what you would do in real life vs what you would during an interview.
Personally, if the patient's life is depended on my actions, I would go and file ASAP report later.
Personally, if the patient's life is depended on my actions, I would go and file ASAP report later. I guess you can call that different kind of works require different kind of approach. I don't know, just my personal preferences.
Lol, then I probably don't want to work there to begin with.
If that is what you are going to do, then do not even file the ASAP report because it is not going to be included in the ASAP program anyway!
You've intentionally disregarded flight safety and that is in the criteria that would make your ASAP report exempt from protection.
