Tram
1) You preflight the aircraft and notice that one nav light is inop. The nav lights are not on the MEL and are required for the flight. Would you still take the flight to move the critical patient?
Well, personally.. If I was doing the walk around on a flight I knew might save someones life and found the bulb, I'd discover it on the post flight..
How would I answer it in an interview? I'd probably tell I'd scrub it.. Air Ambulance - life and death is the name of the game.. I wouldn't go breaking the "law" to move an everyday patient..
2) You arrive to pull the aircraft out of the hangar and there has just been a heavy snow fall. The tug (which is the only approved vehicle to move the aircraft) cannot operate in such heavy snow. But you do have access to a 4x4 truck. Do you go against company policy and use the 4x4 or do your scrub the mission to move the critically ill patient?
What kinda outfit am I interviewing for? Life and death decisions and no one to move the aircraft?
3) You are 20 minutes from your destination when the chip detector detects a chip in the left engine which causes you to shut down the engine. Do you continue to your destination with the patient, or do you divert immediately to the airport with 10 miles that can handle your aircraft?
Nearest suitable... I think being 20 minutes out makes the nearest suitable the destination..
