If you are no longer required, what is the regulatory basis for logging SIC (unless it's a 2-pilot required airplane; I assume it's not a Part 135 passenger flight)? Don't look too hard, it's not there.
Yeah, I got a bit confused. I couldn't log it if I was no longer required. You are correct.
Maybe not the cross country. The orphaned Part 61 FAQ took the position that a safety pilot may not log cross country time. I do not know whether or not that still represents FAA policy.
I cant find anything, just opinions from non-FAA sources supporting both sides.
Here is my take.
61.101 says to log XC, for the purpose of gaining a rating
- Conducted in appropriate aircraft
- include a landing at a point more than 50 miles from the point of departure
- be conducted using dead reckoning, pilotage.....to navigate to the landing point
The general definition includes "conducted by a person who holds a pilot certificate"
Also, for ATP the landing is not needed, only the distance from point of departure.
If, prior to departure, it is decided that the safety pilot will be the acting PIC, he is responsible for the flight. I take that as meaning, he is the one conducting the flight. The reg does not say who has to land the plane, just that it has to land. If you want to pply the time to your ATP, the plane does not even have to land.
If you take that a step further and an IR rated pilot files an IR flight plan and allows a PPL to fly while he is the safety pilot, then he is the acting regardless and even if the foggles come off, he is required the whole flight.
However, that is just my take and I am not in any position to make a determination. If the Part 61 FAQ that you mentioned still holds true, then I am wrong. Wouldnt be the first time and certainly wont be the last.
If anyone has a more recent FAA interpretation that would be great.
