Hard Landing / Substantial Damage
Advantage of the engine mount is that it's easy to change proactively when you do a routine engine change. If you're changing the engine anyway it's another 5 bolts and pull the nose gear out and you can send the mount off to the welding shop to get stripped, NDT, repaired, etc. with a firewall fix, you're just getting started at that point...
I don't know much about the 4 seater class, but as a mech it's not even close in the 6-seater arena. PA32>C200 series all day erry day.
I would say that.
We had a high timed Arrow at the FBO/school I worked/flew at.
Landing gear actuator broke the mount and it was out of service for months while the Engine mount was being repaired. A mount is a 6 month lead time item to order from Piper.
Same school years later had a student drop a 172 on its nose on a solo and required a lower firewall replacement and repair and that took about 6 weeks altogether. Mind you it was a '97 172R with 9k hours on it... it's not as expensive as everyone is making it out to be, there biggest cost was the prop strike, not the firewall damage.
I would say that.
Apples to oranges. Compare issues with the Arrow to a 172RG. Arrow wins all day erry day.
I would say that.
All bets are sort of off when it comes to flight schools because a 9000hr 172 with damage history rents for 130 an hour and a pristine 172 with low time and no damage history rents for.... 130 an hour
Sent from my XT1650 using Tapatalk
@Pilot Fighter , @Plata , @deadstick
My apologies, I didn't realize it was a late model Skyhawk. The ratio of repair to hull value is a little different in that case.
Although in my experience, I've seen something as new as a 5 year old Skylane go to the graveyard due to propeller strike & firewall damage.
Airframe and Powerplant (A&P) mechanic able to address the repair procedures used to bring this (N2104H) or any aircraft back on line with ‘buckling’ damage.
https://app.ntsb.gov/pdfgenerator/R...ID=20150325X24417&AKey=1&RType=Final&IType=CA
"A routine maintenance inspection was conducted on the airplane and the mechanic noticed substantial damage. Buckling was present in the lower firewall and the floor under the rudder pedals, consistent with a hard landing. No hard landings were reported to the operator. The circumstances, crew, and timeline surrounding the damage is unknown. It is unknown if there were any pre-impact mechanical failures or malfunctions with the airframe or engine that would have precluded normal operation.”
http://flightaware.com/photos/view/563408-606b6fe1d50b49d09600144666a00ef07e95fa64/aircrafttype/C172
Harrumph, what's been happening at CIA?
