tonyw
Well, S-Turns are invaluable if you should ever need to make an immediate emergency landing, and the only sutibale field is nearly right below you.
Turns around a point will come into use whenever you want to check the windsock at an airport while flying above traffic pattern altitude...or when the tower instructs you to do a 360 degree turn on the downwind to create more space between you and another aircraft.
Huh? How does doing an S turn across a road or power line teach me how to do an emergency descent? By the way, that's a manuever I think should be on the checkride.
I don't understand why doing a turn around a point would be helpful when it comes to checking out the windsock. Can you please explain that one to me?
