Here are some extracts from the Airplane Flying Handbook, Chapter 11, that impinge on the subject at hand. My view is that the authors have a deep misunderstanding of some aspects of an aircraft's interaction with its environment that I hope will be obvious once I point them out.
Ok, I'm already wondering whether I should read any further. The authors reveal a fundamental misunderstanding about flight mechanics. Airplanes, while flying through the air, cannot “feel” steady wind. The airplane is flying in a body of air which happens to be moving relative to the earth, but the airplane doesn't know that. The only wind it feels is that generated by its own motion.
If you're coming in for a landing using the wind low method, the aircraft is sideslipping in the direction of the wind, so the relative wind that it “feels” is produced by its own motion through the air. If the airplane is sideslipping to the left to counteract a left crosswind, the relative wind is produced by its sideslipping motion, not the crosswind itself, and this relative wind would be felt anytime the pilot applies his flight controls in the same fashion. (i.e., sideslips are idential aerodynamically to forward slips.)
Huh? If the airplane is crabbed, there is no sideslip and the airplane is completely unaffected by the existence of the crosswind, particularly since the aircraft cannot feel wind at all. This language “eliminated to a slight extent” (in the vein of being slightly dead or a little bit pregnant) suggests, once again, a complete misunderstanding of how wind affects airplanes.
Lowered wing blanketing the upwind flap? Where exactly do the authors think the relative wind is coming from? They seem to envision that it moves parallel to the horizon and hits the lowered wing from the top, which would indeed blanket the flap...and the entire wing, resulting in a rapid fall from the sky. In reality, the relative wind strikes the wing from below, like always, but just slightly from the left or right, depending on the direction of sideslip.
Sounds a bit vague, but overall wrong; flap deflection reduces the dihedral effect, according to all the aerodynamics books, so that makes lateral control easier with flaps deflected. Less stability equates to more control. And remember, there is no crosswind, only sideslip.
There is no crosswind to the airplane, there is only sideslip and how could that change as you get closer to the ground, assuming your flight controls remain positioned the same? You probably will encounter increased mechanical turbulence, but also a slower wind speed, which requires less sideslip and thus increases the controllability of the airplane. With strong winds, it's often impossible to achieve enough sideslip to maintain runway centerline at higher altitudes, but becomes possible the closer you get to the ground, which belies the authors conclusions, much less their explanation.
I'm assuming that the author is talking about after touchdown. NOW we have a crosswind, since the airplane is now on the ground, and the air is moving relative to the ground, rather than due to the aircraft motion. It's quite true that the airplane will attempt to weathervane...that's what the vertical stabilizer does. The flaps will likely contribute to this, since they increase directional stability. Moreover, since the airplane is now at a constant AoA, the flaps increase lift and thus reduce the controllability due to differential braking or nosewheel steering. Raise them! This is the only significant and accurate thing the authors have stated in this section. Raise the flaps after touchdown!
Well, we know that not all flap installations cause a nose down pitching motion. Although flaps alone do produce a nose down moment, downwash on the horizontal stabilizer can offset and exceed this nose down tendency.
Given that the aerodynamic center of the wing is behind the CG (or should be), the increase in lift should pitch the airplane down, rather than up. But there is also the propeller blast on the horizontal stabilizer to consider, as well as the Propeller Normal Force (caused by the change of direction of airflow through the propeller disk) which will produce a nose up moment that will assuredly exceed the nose down moment of the lift increase.
That's why when performing a go-around, you're supposed to increase the AoA as you raise the flaps. Didn't the authors read their own chapter on go-arounds?
In cleaning up the airplane during the go-around, the pilot should be concerned first with flaps and secondly with the landing gear (if retractable). When the decision is made to perform a go-around, takeoff power should be applied immediately and the pitch attitude changed so as to slow or stop the descent. After the descent has been stopped, the landing flaps may be partially retracted or placed in the takeoff position as recommended by the manufacturer.
Edit: I won't even bother anymore. Bottom line, there is now one flap setting that works in every situation.
