An increase in AoA will also result in an increase in induced drag. Still gonna get you to the same spot, short of the runway.
Your understanding is flawed. You think 65 knots with full flaps has the same glide angle as 65 knots clean? The lift coefficient is the same, but the drag on the flapped airplane is much greater due to the parasite drag of the flaps.
You're using a faulty understanding of the aerodynamics to argue that it is not possible to do what I do. You seem very resistant to new information, dismissing it without experiencing it.
I would rather have taught a pilot to deal with every foreseeable circumstance, than one who thinks that they need 30 deg. of flaps when it's 16022G38 landing on rwy24 with full flaps to the wind like a sail, and the gust is 3kts above stall speed.
Flaps don't work that way and it's one of the lessons I want to teach them.
. I want my students to pass their check ride as much as the next guy. But I also want my students to walk away from their check ride with the examiner thinking "Wow, all of his students are really effin good."
That appears to be a jab implying that I train for the checkride but you train "aviators". Pretty much every instructor thinks that way about themselves, so I will avoid posturing.
Regardless, you don't understand what I'm trying to do. I want them to
1) Not have this superstitious fear of flaps in windy situations
2) Understand that the purpose of flaps is to lower the stall speed in order to have the slowest touchdown speed
3) To be able to fly the airplane in the most demanding configuration
4) Remove one extra variable during landing to let them focus on flying the airplane.
I find this sort of discipline extremely effective in enabling the students to extract the maximum performance from the airplane with minimum effort, since every landing is (almost) a max performance landing. As I pointed out previously, landings at lower flap settings are childishly easy compared to the maximum drag configuration, so insisting that they use lower flap settings is a wasted lesson. (Other than no flap landings, of course.)
Bottom line: The discipline of using full flaps as primary landing configuration contributes to a long-term improvement in airmanship and increase in confidence. In contrast, inconsistency in flap usage often correlates with a flawed understanding of what flaps do and how they behave in various environmental conditions, and connotes a pilot's lack of confidence in his ability to control the airplaine.
