GolfChuck
Trustworthy Source
We have fam flights all over the world, but we have no cockpit access yet. Stupid.
so what is the point then?
It should be clear that it's not strictly an able/unable decision. If it's annoying that pilots are trying to work out the best altitudes based on these factors, making sure that they have adequate reserves on arrival, I apologize. However, not everything up there is cut and dry, and nobody is screwing with you just for "funsies."
I'm sorry, but if a pilot tells me unable, receives a descent clearance, and then requests the altitude that s/he just told me they were unable, then that tells me they lied to me the first time. I would not be asking if I didn't need the altitude. Nothing wrong with saying able and requesting a different altitude at the same time, at least then I have the whole picture. The more information I have, the better.
Example 1: Aircraft underneath you is requesting your altitude. I ask you when you are able next highest. You respond able, I climb you, climb the other guy. You respond able, requesting to maintain altitude, then you get your request since you were there first, and the other guy has to wait.
Example 2: Adjacent center will not accept you at your present altitude (say you are at f360) the altitude options given are f390 or f310. I ask if you are able f390 by the boundary. you answer able, you get the climb, you answer able, request f360, you still get the climb, but I'll try to keep you at a lower altitude as long as traffic permits. you answer unable, then you get a clearance to f310 (and again I will keep you at your requested altitude as long as traffic permits). However, if you come back and change your mind about f390, it is only going to annoy me. Workload permitting, I will try to work out f390, but since you lied in the first place, getting you to f390 becomes a low priority. Also, in many instances, the second you respond with unable, I (or possibly the next sector/center) will already have someone else lined up for that altitude.
Bottom line is be honest the first time. Safety is the #1 priority, but when the aircraft in my sector are happy, so am I.
