RedBaron2000
I have my check ride scheduled for the 15th, and I feel I'm mostly prepared for my initial CFI-A test. I've been studying hard the FOI , trying to learn it practically speaking but also memorize a good bit of it.
Do all the various lists in the FOI need to be memorized cold? I have created roughly 8 pages of notes of all the various lists in the FOI material, separated by Task and number under that task, so I feel very confident in being able list, explain, and give examples of say, the 7 levels of learning under the psychomotor domain of learning, for example, as long as I can use my notes. I'm just not sure I can list every defense mechanism from memory without forgetting a couple, or every common obstacle to learning from memory, etc. I feel fairly comfortable with the FOI material otherwise, and I've memorized quite a bit of it using the familiar acronyms (REEPIR, COIL, RUAC, LISF, et al.).
So I guess I'm kind of asking, can you use notes for the FOI section of the oral? I know the rest of the CFI oral is basically open book.
