mightynimbus
Twin Commanders are the first plane not to fly if you don't want the wings to fold on you. You know the history and the AD history, right?
How many times have they folded up?
thank you for saving me 5 seconds !!!A ten second search revealed:
"From approximately 1961 to 1993, 24 aircraft crashed when spar failures caused the loss of the wing in flight.[18] Thirty-five more spars were found cracked during inspections.
This wasn't anything to do with FlyingWildAZ on YouTube? I know they have a Commander.
Turbo Commanders. Why they don’t call them Turbine Commanders, I don’t know.Twin Commanders are the first plane not to fly if you don't want the wings to fold on you. You know the history and the AD history, right?
'Cause the JetTurbo Commanders. Why they don’t call them Turbine Commanders, I don’t know.
As an academic I'm sure you're aware of the term "economy of language". The point is to to use the least amount of words possible and still provide a concise description or opinion. This also seems to translate to ones post count on any message board, each post made seems to dilute any credibility from an overly vocal contributor, especially so when that person seems to think it's their duty to educate the other members. Knock it off.'Cause the JetAeroDeathstar had yet to be built?
Turbi??
G-money Commanders?
Asking that is like asking how many licks it takes to get to the tootsie-roll center of a tootsie-pop.
Awesome steed. I'd love to fly oneTurbo Commanders. Why they don’t call them Turbine Commanders, I don’t know.
Do you have a crush on me? C'mon... admit it. I really love all your attention, but you're not my type. (heart emoji)As an academic I'm sure you're aware of the term "economy of language". The point is to to use the least amount of words possible and still provide a concise description or opinion. This also seems to translate to ones post count on any message board, each post made seems to dilute any credibility from an overly vocal contributor, especially so when that person seems to think it's their duty to educate the other members. Knock it off.
I didn't read all that but did they render an opinion on if there was cracking that should have been seen during routine maintenance? I think they use those as lead planes and I can see how they could get beat up. Thanks for posting. I've always wondered what happened with that one.
It looks like the docket for this one was published in November. Nothing terribly groundbreaking. The left wing was found intact almost a mile away from the main crash site. The materials analysis suggests the wing spar fractured from fatigue as the result of overstresses experienced in its lifetime.
NTSB Docket - Docket Management System
data.ntsb.gov
RIP, Matt.
Wait what….guess I need to look at that docket nowI'd say the groundbreaking piece is Textron looking at the inspection photos and telling them they needed to replace the spar, and them not doing it. They won't, but someone should be behind bars for that.
That’s actually really common. GA Manufacturers don’t want to deal with drawing complex repairs so they’ll just tell you to replace everything. As a mechanic and IA, or an operator, if I have data from a DER and a repair competently accomplished per that data my hands are clean. I’m not a structural engineer and it’s not on me to check their work other than glaringly obvious stuff. The DER should absolutely be in hot water though.Let me know if I'm reading it wrong - from the Factual Report ...
FAS submitted a structural damage report and service request detailing the crack indication to the Textron Aviation structures group on April 12, 2021 and followed up with photos of the hole location on April 13. Textron Aviation responded to FAS on April 14 that the crack indication necessitated the replacement of “the center section forward spar cap, center section forward lower fittings and both outboard main spar assemblies”. The email response from Textron Aviation to FAS also included the warning below from SIRM 57-13-01 (in part).
WARNING: A crack in the center section lower forward spar cap necessitates the replacement of all lower forward inboard fittings, the lower forward spar cap on the center section, and both outboard forward wing panel main spar assemblies.
FEA and FAS elected to repair the wing spar at BL 29.27 instead of replacing the spars and contracted with a FAA Designated Engineering Representative (DER) at Callahan Aircraft Services, LLC for the design of the repair. The repair involved oversizing the affected fastener hole to 0.328 inch and installing an external doubler around the hole location. The repair was installed and signed off on May 24, 2021, with an FAA Form 337 Major Repair and Alteration and included a FAA Form 8110-3
OK so after reading more….the crack was in an area that is under an AD and that is where the “replace such and such parts if a crack is detected” comes from. I don’t know how much authority a DER has to get around that and if end-running the AD by a DER is common in the king air world.
The DER might have absolutely messed up, but they may also have assumed the airplane didn’t have a history of a bunch of yahoos over-Ging it and then lying about it. There’s no amount of math that can fix that part.
