Aeronautik
Here's the thing, kid. You're old enough to know that you shouldn't be failing anything in high school, let alone 3 classes. To answer your question of whether or not it's going to hurt you getting an airline job: yes, it most certainly will; because the habits you make now will stick with you. Failing 3 classes shows you really don't care about school--you don't have your priorities straight. I wouldn't want some slacker in command of a $140 Million dollar jet, with 300 passengers behind. You need to straighten up and get your priorities in order. Lucky for you, you're only in 9th grade, and most colleges don't look at 9th grade (unless you fail everything--which seems to be what you're doing). The pilots that command those planes earned it, and they did it with hard work and focus.
Remember that not just anyone is going to get that airline job. You have to separate yourself from a pretty big pool of other prospectives, who most likely have performed well in highschool, and gone onto college to perform well. You should be eager to peform well and shine in high school, with that goal of being an airline pilot in mind. That way, when you make it, you can look back and say you worked hard for it, and have something to fall back on.
Start doing well right now. If it requires going to summer school to make up 3 failed classes, then I don't see what's stopping you. At least it'd show that you're mature enough to know you've screwed up and you're going to fix it. You have to have a positive/succeeding attitude now, or else you're going to be a slacker for years to come. I hope you get straight A's next semester and the remainder of your college years. Do that, and you've proved to yourself that you're a sharp kid and capable of succeeding.
Good luck,
Aero
Good luck,
Aero
