Drones and Common Sense Rant
Let me try to answer your post [HASHTAG]#205[/HASHTAG]:
"no eyes on them and why the hell do they need to be at that altitude?"
Now I should ask you if you are kidding me. Why do we fly in a full scale plane in 10000 ft in our spare time? I think some of you have no idea about drones. A UAV has at least one camera, often two and some of them three. The camera(s) can be tilted and panned and you can switch between cameras. If you fly a Cessna 17x then you have no view upwards or downwards, you can barely look behind you. But with a drone you can!
Maybe we have a misunderstanding here. I guess most of you think about the small quadcopters, up to 14" in diameter, when you talk about drones. These toys are hard to see, like birds. I am talking about bigger things and especially planes. An RC model can be flown without any permission up to an AUW of 55 lbs. With this you can build planes of 20 ft wingspan that can fly for more than 40 hours. Some drones can go 200 kn.
The smallest manned aircraft that I know is the CriCri. It has a wingspan of only 16.5 ft. But it is fully accept in the air. Why shouldn't it be allowed to fly a drone, bigger than a CriCri?
How big should a drone be before you accept it in the air?
Today you only need a driver's license, a minimum of 20 hours of training, passing a written, an oral and a practical test to fly an LSA. Why do you still need to sit inside a plane if you can fly it with a remote control and camera(s)?As the name implies, the feature allows for your drone to automatically return to the point from which it took off in emergency situations like loss of signal from the controller or battery level dropping too low.Don’t tell me that it could fail. There are enough examples where pilots failed. And the drones have something that is called failsafe and RTH. That's safer than most pilots.
What is LEO?
"How about actual aircraft in an emergency situation? What about rescue helicopters and medical helicopters? What about firefighting planes and choppers?"
The rule is: see and avoid. You can also do it with a drone.
Thank you for the following questions:
"How about search planes and choppers?" These flights are the first to be replaced from drones.
"What about mapping and surveillance aircraft?" This will soon be replaced from drones.
"What about aircraft and choppers flown by and for ranchers, and farmers for various reasons?" Agriculture is the best example for the useful operation of drones.
"What about Fish and Game aircraft?" Same like agriculture.
I think you don’t know what is going on.
The military is flying drones since the 1960s. Now the technology is available and affordable for more people. Give them their space to fly!
I think some of you are still living in the last century.
We don’t need to talk about commercial IFR flights. No one should cross their way.
I am only talking about class G and E airspace and VFR.
I knew the "Know before you fly" campaign since it was started.
I don't think that YOU have a clue here. No one here has mentioned size either, yet you assume that everyone is thinking is very small UAVs which is not the case at all, as far as I am concerned. No one here had even mentioned size. You are demanding space and demanding it now. You believe that all survey flying and other types of flying will all be accomplished with drones. What year/time frame do you see this happening exactly?
LEOs are Law Enforcement. You have medical, law enforcement, search and rescue, firefighting, Fish and Game, Forestry Department and more different entities, aircraft and choppers all flying out of the normal "areas" of airspace. That is they may be flying very low to the ground, flying at night or in the daytime, flying the quickest route possible, flying different patterns depending on what their current operation is at the time, etc. So your idea of classes of airspace for drones goes to crap entirely in these scenarios since these aircraft will not be flying in normal flight paths to begin with.
How do you explain the drone that nearly hit the medevac chopper last month (post 213) up by Fresno and came within twenty feet of it, and the chopper had to maneuver to avoid it. That drone was 4 to 5 feet wide according to the pilot of the chopper. Where was your "see and avoid" scenario there? How well were all the drone's marvelous cameras working in that situation? You keep harping on commercial flights yet you are clueless as to all the flights that go on daily by the entities which I listed that are not commercial flights.
You think that see and avoid is going to work with drones sharing the same airspace with the choppers and planes flown by the entities that I am talking about? Good luck with that. Cameras or any high-tech sensors on a drone cannot fully replace a pilot’s eyes and ears and nose in the cockpit, no matter what your personal opinion might be. Are hobby remotely controlled planes or drones equipped with radar or anti-collision systems? Not so much.
And what sort of real training do hobby drone flyers get no matter how large their drones are? Oh yeah..........that would be none.
Are you working on that air space proposal in L.A. County that I asked you about, btw?
Would you care to respond to post 226 and your ridiculous idea of a flyer btw?
Let's talk about the "failsafe that you mentioned, while we are at it. Isn't that technology used to land the drone when your GPS signal goes to crap and has nothing whatsoever to do with avoiding another aircraft? "A failsafe is a pre-programmed behavior designed to prevent a crash in the event of an unsafe situation. All ArduCopter for example vehicles include a GPS failsafe activated by default. 3DR RTF copters are also preset with radio control (RC) and low battery failsafe behaviors. If the drone looses GPS signal in a flight mode that requires GPS (loiter, auto, return-to-launch, guided), it will land automatically, indicated by a blinking blue and yellow status LED and a high-high-high-low tone". So what does this matter in avoiding a plane or chopper exactly? Because that is the issue here, not that fact that your damn drone can find it's way back to you.
And when you say "That's safer than most pilots", this again reeks of your envy of actual pilots much like your "big boys with their big toys think that all the sky belongs to them", ridiculous comment.
And RTH technology? Return To Home, as the name implies, the feature allows for your drone to automatically return to the point from which it took off in emergency situations like loss of signal from the controller or battery level dropping too low. How does that help you avoid aircraft? I mean you mentioned these two features and said they were safer than human pilots. WTH??? Seriously? What sort of analogy is that?
Interesting that you mentioned the Military and their drones. You do realize that 47 military drones crashed in the United States between 2001 and 2013 in what the military categorized as Class A accidents, the most severe category. And that more than 400 large U.S. military drones have crashed in major accidents around the world since 2001. Military drones have slammed into homes, farms, runways, highways, waterways and, in one case, an Air Force C-130 Hercules transport plane in midair. One barely missed an elementary school here when it crashed in the school yard. Several military drones have simply disappeared while at cruising altitudes, never to be seen again. Dozens of drones have been destroyed in the United States during test and training flights that have gone awry. In Upstate New York, the Air Force still cannot find a Reaper that has been missing since 2014, when it plunged into Lake Ontario. In June 2012, a Navy RQ-4 surveillance drone with a wingspan as wide as a Boeing 757’s nose-dived into Maryland’s Eastern Shore, igniting a wildfire.
Then you said (which really makes no sense, not surprisingly enough, however)
That statement alone, tells me you have never been a pilot flying anything except for RC hobby planes and hobby drones.
People fly LSA (and not just LSA) for the actual joy of flying. You have absolutely no experience or feel of flight when you are standing on the damn ground. You might as well be at home playing some SIM game on your computer. The ethereal feeling of flight comes from actual flying. It's not only the physical aspect, it's the spiritual aspect. It is the freedom from gravity, it is the leaving of the earth and it's boundaries. It is the views.......the views of the multitudes of different clouds, passing through those clouds, seeing the incoming storms, the sunrises and sunsets, the mountains, rivers, the sea, the earth, the dark inky sky lit up with millions of stars........ all seen from aloft that only a small percent of the entire population of the world will ever get to see and experience on their own terms, while they themselves are at the helm. It is liberty from the ordinary. It's where your soul yearns to go. Flying is a passion. It is extraordinarily unique amongst all of the pleasures that a human being can possibly partake of. It is an activity which is both pure and beautiful. Had you ever been a pilot, you would understand this. I feel sorry for you that you can't imagine the enormous value of actual flight. If you think that looking through some camera can even begin to compare, then you are even more clueless than I had originally thought.
I heard that today on the news. Nothing he does should shock me any longer, but I had hoped he had more brains. I was wrong about that apparently though. They should have presented it to him after his nap. The man whose brainchild is California's Train To Nowhere- the legacy that keeps on spending........I mean giving.
Drone flyer, I have extensive FPV experience, and more years than not flying professionally. If you are flying a model beyond LOS, there is no way to see and avoid, or to have any spatial SA. To suggest otherwise is wishful and naive. I have seen videos of jackwads flying over major metropolitan areas at stupid altitudes and can actually see on the video major airports nearby.
There is no way that a drone shows up on ATC for traffic alerts, and no reason why an airliner with direct operating costs approaching 30K an hour should have to perform ANY maneuver to avoid a conflict.
Your ignorance is the major problem.
What an idiot. And not even keeping with usual DNC pandering, either. Democrats are usually happy to sign legislation that would give trial lawyers more cases. Can't understand his reasoning here at all.
That legislation was pretty over reaching. Basically made it a crime to fly 350' AGL and below without permission from landowners. The original bill had everything to do with privacy but it was since amended and went too far, stifling innovation and uses of them.
Here is a good read from Forbes:
http://www.forbes.com/sites/gregorymcneal/2015/08/11/californias-drone-trespass-bill-goes-too-far/
I used to do aerial photography when I worked at a flight school. Why aerial photography would remain legal and use of UAVs to do the same doesn't pass the logic test.
Sounds like it didn't go far enough to me.
/yawn
What is just as bad as this foolish, dangerous stunt, is all the people who are supporting this flight, saying how cool it is, how they want to try it, giving suggestions to prevent the drone from crashing, try this, try that, and on and on. Instead of making a sane person see the reckless endangerment of this behavior, it seems to have the opposite effect of 'wow, I can't wait to try something similar'. So much for the so called Failsafe and the RTH features of these drones, which both failed. He has yet another video where he's at 300 meters and loses control because of the wind, so when he stated he put the other video up as a learning experience, apparently the only thing he learned was pretty much nothing. Even when his Go pro camera is tumbling through the trees and again tumbling after hitting the ground, he can't understand "why it is spinning". Good grief. We should hook him up with all the idiots freaking out and reporting aliens when the Navy launched and tested a missile last night from a sub off the coast here. I mean it's not like we've had and seen dozens of these before or anything.
If drones are going to be flown to get that kind of aerial footage like that. Then people need to have a license to operate them, and operate them in accordance like everyone else operating in the NAS, and if they can't then they need to have enough $$$ to be able to get a TFR put up for whatever it is they need to do in that area... Otherwise, get out of our way... We're busy operating real aircraft with real lives through the NAS.
