DOT Sec Buttigieg: Domestic Testing Being Seriously Considered
Another thing to note is rapid tests have a false positive rate of 1-2%. With the current COVID infection prevalence between 0.2% and 0.3% in the US, that means 84-89% of positives will be false positives. If you scale this by close to a million travelers per day, that's a lot of false positives. A lot of healthy people who won't make their meeting, or won't make their commute, and will definitely be out the cost of their ticket. That would be enough for me to chose driving or flying a clapped out 172 instead, regardless of how convenient the process is made to be. That's why passenger numbers will fall drastically.
Hopefully since the current administration "follows the syance" they will read these same papers and others like them to conclude that it is indeed a bad idea.
i suck at math, so correct if I’m wrong here, but if rapid tests have a false positive rate of 1-2%, that means that 1-2% of positives would be false positive, not 84-89%
I think the 1-2% means 1-2% of all truly negative tests will give a false positive. However, he’s off by a factor of about 8 on the currently infected population-we’re probably about 1.7% of population currently infected, not .2%
I went into the doctor and they asked if I had traveled anywhere in the last 14 days. I asked them “how do you define travel?”.
“Well, you know, away from home”.
“Um, I’m away from home right now”.
<blank stare>
Comment score -1 unhelpful.
My clinic was all “oh, airline pilot - okay - well - any close contact with anyone symptomatic?”
The 0.2% prevalence was from the paper as of Nov 2020. I think we're at a similar point today having gone higher during Dec-Jan. But let's say it's 1%. At that prevalence 2.5% of all tests will be positives. If we take the Abbot test, 1.5% will be false positives. So 60% of all positives will be false. That's based on the data from the ASM article
<blank stare>
I had a dentist appointment, and they called me the day before with a list of COVID questions. We got to "Have you travelled recently?"
I just said, "Y'all know I'm an airline pilot."
They kind of chuckled and said they'd see me tomorrow.
Had the same issue.
"Well, I want to be honest, but also if this is the case I'm literally never going to be able to have my teeth worked on."
"It's fine."
Which seemed kind of silly to me since other than work and the store I basically don't go anywhere. Not a single question on "have you been at the Chili's bar down the street that is inexplicably packed every time you drive by?"
