Do not let ATC fly your airplane
Autothrust Blue
“If you jump on my shift, that’s just rude, man.”
If you think you need 17C (and say you need 17C, and you're concerned about having the fuel to make right traffic for 31R and you have M&Ms melting in your hand), then you need 17C - don't be whipped into taking 31R, just because it fits with the "flow".
Reminds me of the AA pilot that laid down the law at JFK.
"Three times I've told you that. Three times we've declared an emergency."
"Remove everybody from our way... we've declared an emergency."
Pilot was pissed. Understandably so.
I remember this, but I'm not sure I ever heard what actually happened with this fella?
~Fox
I don't get this at all. Description on youtube says that he could not accept rwy 22 because of crosswind component, and declared an emergency. Fine, but why did he just start turning for runway 31 without clearance? As far as I know he didn't have a fuel emergency, he just couldn't land on that specific runway. Seems the prudent thing to do would be to try to work out vectors as long as he's not minimum fuel. But instead he declares an emergency and turns wherever he wants separation be damned. WTF?
YouTube descriptions rarely have anything to do with the videos.
I guess it was a low fuel emergency...sounds like "we can't land on the runway you're wanting us to, but we don't have enough fuel to go to another airport....so we are declaring an emergency in order to get the other runway"
At least that's how it sounded to me.
Although I never heard them mention anything about low fuel, so it was hard to figure out exactly WHY they were having an emergency. Anybody have other info on what happened here?
Video #1 ATC was way worse than #2. In the first the pilot declared and made his request with Center! IE they had all the time in the world to accomodate any request. They had plenty of time, to coordinate(in those cases ALL the pre-coordination is done supervisor to supervisor. I don't care who the FAA tries to blame the Supervisor made that call not any individual controller). In # 2 the pilot threatened to declare in order to get what he wanted at the last second, then acted as if his threat was an actual declaration and the controller was ignorant. Blame get's shared there, whereas in the first video, the pilot did everything right and ATC( as one entity sups/controllers) holds the blame.
The on-going (and much over-exaggerated) joke when I was based in DFW was "DFW Tower, Delta 123, mayday, mayday, we've lost an engine and need to return immediately!"
"Delta flight calling tower, standby. American 45, you parking in the A terminal? Ok, inboard's available if you want it, cleared to land, long landing approved have a great day. Eagle flight 385, position and hold. Aircraft calling with the emergency, say again?"
Sent from my TRS-80
Winner, winner chicken dinner...
Moving forward, the words "Be advised I was just informed by a supervisor to instruct you unable runway XX, expect runway YY - say intentions..." have actually come out of my mouth.
Yeah, that QAR ended well.... :)
"May I suggest a closer airport if you're that low?"​
Uh, may I suggest a different occupation if you can't handle an airplane inbound to your seven-runway airport with a possible fuel leak?
Just throwing this out there, but if you notice when the coordination was done (not with the receiving controller directly) the part that the aircraft could possibly be leaking fuel was not relayed. It was stated as a fuel emergency, which to us is a step beyond minimum fuel...and a big difference than "the aircraft is possibly leaking gas."
At times, there is some disconnect between left hand and right hand. First and foremost, my job is to weed out that disconnect and try to make it right...
It's an emergency. Doesn't matter what. Give him what he wants unless it's going to cause big boom.
While this is true, one HAS to temper this "move everything out of the way for me NOW" attitude, with understanding that it might take time to do that.
Years ago, I heard something on the ATC freqs that caught my attention. There was an IFE (inflight emergency) in progress. In that instance, an aircraft declared an emergency in Class B airspace. The weather was broken CB with rain, enough-so that IFR aircraft were being vectored to instrument final, with no visual approaches being issued. The aircraft with the IFE (rough-running engine on a Cessna 421) couldn't understand why he wasn't getting immediate vectors to final to land, and whyhe was told to "stand-by" by ATC. He raised hell a few times about it to ATC. But there seemed to be, from my perspective, a few things he failed to understand about ATC and how they work. Now, I fully understand that anytime someone declares an IFE, they expect, and should receive, priority handling to the maximum extent possible. Keep in mind the last part of that sentence: "to the maximum extent possible." When someone has an IFE, their only worry is (rightfully) their aircraft and themselves, but they've got to understand why somethings may happen that may not initially go their way. When an IFE gets declared to ATC, the controller's entire scope doesn't come to a grinding halt. He still has those (possibly) 10+ MTI "blips" to sequence and separate. Once someone declares an IFE, chances are, they've now thrown a monkey wrench into the controllers sequence/separation plan; they're a pain-in-the-ass now for all intents and purposes. He still has his other traffic to work while he works to prioritize the IFE, and may very well have to have the IFE "stand by" while he coordinates with other sectors/tower for the IFE, etc; this workload being possibly multiplied ten-fold if the WX is actual IFR due to sequencing needs and the lack of visual approaches/separation available. Often times, an IFE may just have to recover within the flow that's already in place. It's a crap-sandwitch, I know, but you play the cards you're dealt.
And yes, I've been an emergency before, only to be told I was the #7 IFE in progress, and to proceed to a holding fix and hold as published, due to the nature of my emergency being less priority than the other 6 emergencies in progress and airborne at the time.
Having an IFE isn't any fun for the crew involved, but it can be not-so-fun for ATC also, due to their responsibilities. In the heat of the moment, both sides will have to do the best they can with the situation at hand. Hopefully, reading this, pilots can understand what's going on with that voice that may be telling them to "stand by" during their IFE.
I for sure see what you're saying Mike but I was more commenting on the excuse that they only thought it was a "fuel emergency" and not a "airplane leaking fuel". ATC shouldn't base their handling on how severe they assume it might be unless there is more than one IFE in progress.
Complete agreement on that. I was just giving a general overview for understanding both sides of the equation. But excellent point you make.
