Sounds great! I am finishing up my CFI over at Orion at the moment. If you need a flying/study partner just let me know! Good luck on your ride.
Is that a greyeagle airplane? Who is your CFI..that is my own home base
That kind of happened to me. The examiner said, okay, you pass. Now tell me why you didn't do this -- and pushed the nearest button on the GPS.
Yeah, absolutely. If you've got GPS most examiners will let you use it or any other resource available to find your airport. In fact, if you do have GPS you should use it first as it shows good judgement that you'd use your most accurate and easiest to use resource first. Make sure you know the old fassioned way though, because you may come across an examiner that will flip it off and say "whoops, GPS just failed, now what?".I taught my students the method that is described above and then the examiner says why did you not just use the "direct to" function on the GPS.
My student didn't choke and said that I taught him both ways but was instructed to do it the old fashioned way for the checkride.
Ok now two things.
I asked my instructor about just turning to the general direction first, and then working out the calculations, and he didn't agree. He told me to just get the correct calculation before hand because i'm going to have to do it anyways, and then turn to it which doesn't make sense because then I asked him how I would get my GS using the e6b while in the air?
Use the compass rose because the headings are already converted to a magnetic heading.One more thing, how would you calcuate your ground speed in the air with the e6b ?? I'm a little confused because the headings are already magnetic, so do I just add 13 to my true heading or just subtract 13 to my wind correction or????
Ok now two things.
I asked my instructor about just turning to the general direction first, and then working out the calculations, and he didn't agree. He told me to just get the correct calculation before hand because i'm going to have to do it anyways, and then turn to it which doesn't make sense because then I asked him how I would get my GS using the e6b while in the air? His response was forget about the e6b, just use a compass rose for the heading, measure the distance with your fingers, I assume calculate time with how many miles it would be, and then figure out my gallons burned by knowing that if you burn 6 gallons an hour, or 1.5 every I think 15 min or 30 min somthin like that, then you dont need a e6b, it would just slow you down. ???Ok but not turning to your alternate airport right away would also slow me down I was thinking but whatever, I didn't say anything.
Then I asked him ok, how would I get my GS in the air with the e6b? He said "forget about the GS for wind correction. In a real emergency no one is going to have time to figure out the wind corrections. Just know what the winds aloft is for the region, and know you will either have a tail wind , head wind, or no wind change depending on which direction I turn to".
So what do you guys think?? I feel good about using the plotter or the e6b during a diversion. Should I listen to my instructor on this one or just do what works best for me? Do you guys agree with what he is saying?
Let me know please.
if your checkride is with Mr Hill or Mr Defrancesco (yes I can say their names online, dpes are public knowledge) both of them will want you to turn right away to the approximate heading of your destination, just ballpark it. Once on approximate heading it will not be hard to get an exact heading. Look outside the window and find a prominant landmark from between your 10 to 2 o'clock and no more than a few miles away and get your distance and heading from there.
why? Im glad you asked....by turning to your approximate heading you are already somewhat on your way so that buys you some time. Now, why do we pick a prominant ground reference to do our calculations? Im glad you asked again, you are catching on....Because it is much more simple and accurate to pick a landmark that you can get a no kidding distance and heading from not to mention it gives you the mile or so it takes you to get there to calculate what you need without having to circle or get more lost then you potentially already were.
as for groundspeed, first just take out your whiz wheel and if you know the winds aloft (you should) you can calculate a rough estimate based on your indicated airspeed and the winds and then tell the examiner that it will take you x amount of minutes to get to your destination and let your examiner know that you will have a more accurate reading momentarily along your route, he will be ok with this. So now....once you pass your point that you are referencing as your start position just jot down your time and then pick another landmark a few miles along your path and write down the time you cross it. Now you have the distance traveled and the time it took you so you can compute that into groundspeed and give the examiner a more accurate estimated time of arrival
now the great news. If you just turn to the initial heading and tell him how you will get there, compute up a rough estimate on the estimated time of arrival that will satisfy the examiner and he will definately move on to the next task. Your examiner is going to make 450 bucks for this ride whether it is 3 hours or 1.4 so he is shooting for the 1.4, if you are competent and do the right things and look competent he will move right on.
Have faith in your instructor because he can at least teach you to fly as good as he can but also remember that there are better ways to do somethings and if you tactfully suggest that you try another method because it makes more sense to you he will at least owe you the explanation of why he does or does not want you to do that. Just remember, instructors do not know everything and I have had students prove me wrong a few times.
regardless of your examiner tell them I said hello, I have had about 3-4 rides with each of them. Both awesome guys
