You had that much water in the fuel?In regards to the OP, we had a motive flow valve freeze up trying to leave Canada once...Got the light, went back, put it in a hangar for 8 hours, problem solved!
We actually drained all 6 drains on each side (can you find all 6? I can, nowYou had that much water in the fuel?
Well there's no moving parts. The only way for motive to not work is if there's no fuel going past it from the pumps or it's blocked.We actually drained all 6 drains on each side (can you find all 6? I can, nowand found no water. It was still our maintainers best explanation for it being stuck shut...
There is a valve that closes when the aux tank is empty. If the valve is "closed" despite there being fuel in the aux, we get a light.Well there's no moving parts. The only way for motive to not work is if there's no fuel going past it from the pumps or it's blocked.
The 10psi is for the the primary boost pump. That gives you the red fuel press light.Isn't the light on if there is fuel in thank and the pressure switch is not registering 10 psi?
I don't think so. I've never heard of that on the King air, and you would think that'd be something the'd bring up since it's often well under 0C here. The pax o2 is either manually deployed via a physical linkage or via a baro sensor and mechanical linkage.I can't remember if there is a limitation on a King Air, but on a Citation the cabin must be above freezing for at least 20 minutes if carrying passengers for proper deployment of the emergency oxygen system.
Or in heavy turbulence! Rubber jungle when crossing the mountains.I don't think so. I've never heard of that on the King air, and you would think that'd be something the'd bring up since it's often well under 0C here. The pax o2 is either manually deployed via a physical linkage or via a baro sensor and mechanical linkage.
I've never had that problem. We've got plenty of mountains to.Or in heavy turbulence! Rubber jungle when crossing the mountains.
We had a couple panels fall going out of Mammoth, CA. in some unexpected severe turbulence. One of the biggest butt pucker moments of my life.I've never had that problem. We've got plenty of mountains to.
We just leave the pilot O2 on, the pax will be fine even if theirs doesn't work in the 45 seconds it takes to go from FL280 to 10,000.-40C for starting and blowing the boots are the only ones I recall.
Definitely check that the valve opens. It has been known to freeze.
How do you turn on pilot O2 and not pax?We just leave the pilot O2 on, the pax will be fine even if theirs doesn't work in the 45 seconds it takes to go from FL280 to 10,000.
ohh, got it...I would hate to run down our bottle, I feel like it MUST leak somewhere..I read it as leaving the ARM handle pulled. We do the same. Ours does a good job of not leaking, but we still check the flow.
Just don't pull the one that drops the rubber jungle and makes the mechanic curse you for a month.
There are a couple of "fun" ways to drop those masks..can you guys hold a 12k' cabin with the bleed air switch on low?
