crazyjaydawg
Know how to fill out an 8710. What if your student does not have an SSN to put on the 8710?
Does your CFI check ride reset your flight review clock?
Who puts an ssn even if they have one?
DO NOT USE works great
91.213.
If the throttle cable breaks inflight, what will happen, and how will you get back on the ground?
What will your MAP be if you run out of gas?
What is required for an airplane checkout?
Correct for the second half of the question, but didn't answer the first part.Mixture
Incorrect, the MAP will be whatever it was before the fuel ran out.Whatever the baro is outside
It's amazing how many CFIs don't know this.Nothing as far as faa is concerned (assuming qualified in category class and type if required)
Oh God! Turning in my 8710 to them next week.
91.213.
Unless you're owner/operator or mech, there is no reason you need to know that.
My opinion only.
Wrong.And Yes the cfi ride resets the clock.
Ok yeah just cutoff the mixture when you feel you can glide down to the airport.
The key thing with fuel exaustion/starvation is that the propeller will keep spinning turning the engine. Therefore the pistons are still sucking air out of the manifold giving your 25"MAP (or whatever you had set), and if you change the throttle the MAP will change just like normal.I also thought that it would read the baro pressure outside because it does that when you cutoff the fuel when on the ground which I think would be the same thing.
I believe the answer to number three is just keep a record that you have checked them out.
If you lost aileron control I think you would use your rudder pedals?
Agree in principal, but how far do you take it? Do you do an AD search before every flight? Do you check the logbook for time-limited components?Read 14 CFR 91.7.
Ok yeah just cutoff the mixture when you feel you can glide down to the airport. I also thought that it would read the baro pressure outside because it does that when you cutoff the fuel when on the ground which I think would be the same thing. I believe the answer to number three is just keep a record that you have checked them out.
Doors
