And if you were my examiner, I would point you towards Chapter 5 of the Aviation Instructor's Handbook, where it says that trick and irrelevant questions "...are not helpful in evaluating the student’s knowledge..."
When there is an "R" in an AD number, what does the R mean?
Ok the R in the AD's means it is recurring. Meaning you have to comply with it in the future. The correct answer to the student pilot flying solo above the few clouds at 1500 is NO. Why no you ask, the student pilot needs vertical visibility to the ground at all times. If you cannot see the ground because of any one cloud then you cannot fly above that cloud. Few clouds is a 1/8 coverage of the sky therefore making it very hard to always have vertical refernce to the ground.
Oh and the exchange in coontrols I believe the positive exchange goes, YOU- "you have the controls", the other person will reply- " I have the controls", then you release the controls.
Endorsement to tow a glider isn't in 61-65E. You also don't need to be a CFI to give one.
Not relevant and also not the one I'm thinking of!
Further revisions since the AD was first issued ?
Unless you're owner/operator or mech, there is no reason you need to know that.BINGO! Give that man a cigar! Right you are sir.
I might also add that if an AD is complied with and a revision comes out, the revised AD has to be complied with. So, if R2 was done and R3 comes out, you once again have an AD requiring compliance. It may be an easy compliance because the revision may not have changed anything that was done, but it still needs to be signed off by a mechanic.
that would be the infamous Dupage FSDO in Chicago....got to love a 92% fail rate, the flight was only 1.9.
I'd say 4-6 hour orals are normal, unless you got one at a pilot mill(ATP) they usually have 1-2 hour cfi initial orals (based on who I've talked to)
If the throttle cable breaks inflight, what will happen, and how will you get back on the ground?
What will your MAP be if you run out of gas?
What is required for an airplane checkout?
