I have an Indian student, and as is the case with many Indians, he cannot make the last ten feet of flight work out in his favor. He is driving the airplane into the ground, then flaring at the last minute, ballooning to all hell, and then not correlating that situation with the fact that he always ends up trying to tear the nosegear off when it happens.
Flies great otherwise.
Advice plz?
And yes, I'm making sure he's looking at the far end of the runway and not right in front of the nose.
I seemed to have the most trouble teaching that phase of the privates as well, I learned a few tricks, some worked, some didnt.
I had one short female student who couldn't judge height well, until someone mention her putting a cushion in her chair to get her higher, it worked!
I also think judging distance above ground is due to looking to far away maybe? I found that if their yawing in every direction that their looking to close, if they are not judging their flare height right, they are looking to far. Maybe even have them look out their side window for a milli sec during landing a couple times. That seemed to help me that my instructor had me do
I been having the privilege of flying with some very high time bush pilot tailwheel instructors in the last 2 months. I also learned some of the following tricks they use that I never really seen in use at flight schools I was at.
One which is the dutch roll, that needs to be perfected, and it just takes 5 min of practice in the practice area every flight, (dont overdo it because they will get sick) cause if they cant do that with natural rudder usage, they wont be able to land in x winds well, They need to be able to do this without looking inside at the ball. Demonstrate Adverse yaw (Roll OUT of a turn with rudder, and OUT of a turn without rudder. A light bulb will turn on when they see adverse yaw. It works a little better rolling out of a turn it seems)
also most of the bush pilots I been flying with dont use 30 degrees of flaps on every landing, have your student do some landings with no flaps, and touch down at around 65 knots, vs 45 knots. you have ALOT more control effectiveness which becomes easier. (teach it like a wheel landing on a tail-wheel except reversed because CG location is opposite side of mains) I was amazed when I was shown that you can even land that fast in a cessna without hitting the nose wheel first, and it makes landing in a 30 knot crosswind easier as you have way more control.
Have the student do a flare the whole way down the runway keeping power in slightly so as to not touch the runway. (just dont do this to long down the runway so you dont hit trees at the end on the on the go-around like I almost did once)
practice power off stalls except dont recover, just hold the yoke all the way back and keep the nose straight with rudder. In my opinion natural rudder usage is the most important skill in landings, and can be learned faster doing certain maneuvers rather then just the few seconds of flare per landing.
It seems like there is one trick for every student, you just gotta find what it is, and thats the fun part of instructing hehe.
Edit: oh and one more thing, I try to avoid using the word flare, I found that a student who thinks "oh its time to flare" will often do it to much which results in a balloon. and the student should not be "flaring" unless he/she is "sinking", and the flare is mostly just "holding it off" (if your practicing stall landings)
