Roger Roger
Bottom of the list
Again, in my experience with TIO540s that will flood the snot out of it. Maybe it's climate, but like I said if the engine is warm throttle cracked, mixture cutoff and crank will have it fire within a few blades every time.Fuel vaporizes in the lines and the priming purges the vapor. With TIO-540s hot just firewall the throttle and mixture then prime until fuel pressure stabilizes and no longer (3 sec). Mixture idle cutoff, throttle wide open, crank. As soon as it fires, mixture goes in half way & bring the throttle back. This has never failed me from starting anything hot from an IO-360 to a TIO-540.... It even works on Continentals.
If you flood it. Turning the engine over with the throttles open, mixtures idle cutoff & mags off will draw more air into the cylinders without introducing more fuel. This will dry the cylinders & plugs out. Fumes burn not liquid fuel. Unlike cold engines, hot engines want to be lean to start. For a cold piston engine think fuel. For a hot piston engine think air.
