TXTBOOK
No, haha, I just hold it down for like 3 seconds.
haha exactly. We get about 10 degrees for every one-Mississippi
Only time I have ever used 40 degrees flaps is on short field landings.(I am unsure for the 172s that have 40 degrees)
2600RPM @ 150kts short final.
Anybody have the RPM/airspeeds for a Cessna 172 & 152 for downwind, base, and final?
I have flown one with that switch. It sucks. The main 172 I am flying does have notches.You have notches on your flap control device (what is that thing called?)? On our 172M you just hold it down until you get the desired flap degree. Not a set-and forget thing, you have to hold it down until it gets to 20 degreees, etc.
Downwind - Slow
Base - Slower
Final - Take a nap, you're not missing anything.
I dream of notch.
They changed sometime in the late 70s I think... the 1973-ish planes I've worked on all have the up-off-down switch.How old is the plane? Mine is an '82 model with the notches.
OMG, your going to kill yourself. You know closing the throttle at that speed is going to shock cool the engine!You will burst into flames and die. It's almost as bad as running oversquare!
