Title 14: Aeronautics and Space
PART 61—CERTIFICATION: PILOTS, FLIGHT INSTRUCTORS, AND GROUND INSTRUCTORS
Subpart A—General
Browse Previous |
Browse Next
§ 61.3
(c)
Medical certificate. (1) Except as provided for in paragraph (c)(2) of this section, a person may not act as pilot in command or in any other capacity as a required pilot flight crewmember of an aircraft, under a certificate issued to that person under this part, unless that person has a current and appropriate medical certificate that has been issued under part 67 of this chapter, or other documentation acceptable to the Administrator,
which is in that person's physical possession or readily accessible in the aircraft.
§ 61.23 Medical certificates: Requirement and duration.
(a)
Operations requiring a medical certificate. Except as provided in paragraphs (b) and (c) of this section, a person—
(1) Must hold a first-class medical certificate when exercising the privileges of an airline transport pilot certificate;
(2) Must hold at least a second-class medical certificate when exercising the privileges of a commercial pilot certificate; or
(3)
Must hold at least a third-class medical certificate—
(i) When exercising the privileges of a private pilot certificate;
(ii) When exercising the privileges of a recreational pilot certificate;
(iii) When exercising the privileges of a student pilot certificate;
(iv) When exercising the privileges of a flight instructor certificate, except for a flight instructor certificate with a glider category rating or sport pilot rating, if the person is acting as pilot in command or is serving as a required flight crewmember; or
(v) Except for a glider category rating or a balloon class rating, prior to taking a practical test that is performed in an aircraft for a certificate or rating at the recreational, private, commercial, or airline transport pilot certificate level.
(b)
Operations not requiring a medical certificate. A person is not required to hold a valid medical certificate—
(1) When exercising the privileges of a student pilot certificate while seeking—
(i) A sport pilot certificate with glider or balloon privileges; or
(ii) A pilot certificate with a glider category rating or balloon class rating;
(2) When exercising the privileges of a sport pilot certificate with privileges in a glider or balloon;
(3) When exercising the privileges of a pilot certificate with a glider category or balloon class rating;
(4) When exercising the privileges of a flight instructor certificate with—
(i) A sport pilot rating in a glider or balloon; or
(ii) A glider category rating;
(5) When exercising the privileges of a flight instructor certificate if the person is not acting as pilot in command or serving as a required pilot flight crewmember;
(6) When exercising the privileges of a ground instructor certificate;
(7) When serving as an examiner or check airman during the administration of a test or check for a certificate, rating, or authorization conducted in a flight simulator or flight training device; or
(8) When taking a test or check for a certificate, rating, or authorization conducted in a flight simulator or flight training device.
(c)
Operations requiring either a medical certificate or U.S. driver's license. (1) A person must
hold and possess either a valid medical certificate issued under part 67 of this chapter or a current and valid U.S. driver's license when exercising the privileges of—
(i) A student pilot certificate while seeking sport pilot privileges in a light-sport aircraft other than a glider or balloon;
(ii) A sport pilot certificate in a light-sport aircraft other than a glider or balloon; or
(iii) A flight instructor certificate with a sport pilot rating while acting as pilot in command or serving as a required flight crewmember of a light-sport aircraft other than a glider or balloon.
(2) A person using a current and valid U.S. driver's license to meet the requirements of this paragraph must—
(i) Comply with each restriction and limitation imposed by that person's U.S. driver's license and any judicial or administrative order applying to the operation of a motor vehicle;
(ii) Have been found eligible for the issuance of at least a third-class airman medical certificate at the time of his or her most recent application (if the person has applied for a medical certificate);
(iii) Not have had his or her most recently issued medical certificate (if the person has held a medical certificate) suspended or revoked or most recent Authorization for a Special Issuance of a Medical Certificate withdrawn; and
(iv) Not know or have reason to know of any medical condition that would make that person unable to operate a light-sport aircraft in a safe manner.
