Thanks for clarifying - - no, it was clear before, I just was skeptical - - thank you for confirming that. That leaves me with this question: What do you use as an aimpoint to ensure a 1,000' touchdown (for your contaminated runway data)?B767Driver said:That's exactly right. The threshold crossing height data and main wheel contact point is now based on an aim point of 1000'. The contaminated analysis is based on touchdown point of 1000'. Definitely a difference between aim point and touchdown point and one I definitely meant to distinguish between.
I'm not sure why you're reluctant to use the terminology, because it accurately describes the maneuver you're presenting, When you go below the glidepath to land at a point priior to the normal touchdown point, that is a duck under. Since you have data for it, why not call the spade a spade?B767Driver said:Absolutely no "duck under" going on here. I would never use those words at any time under any situation. The verbage is "runway in sight" "taking over visually".
B767Driver said:I believe the CFR's you quoted give the latitude to maneuver as I described. It is now necessary to land...I will be leaving the electronic glideslope for a visually performed landing. There is nothing unusual or unsafe about maneuvering for a new aim point to acheive the required touchdown point objective. Especially when you are given approved data for such a maneuver.
AS a matter of fact, such manuevering is required to acheive the necessary stopping distance as stated in the engineering analysis.
IF one has valid manufacturer data and a proscribed normal procedure to descend below glideslope to accomplish a normal landing, then it's hard to argue against it. Until this discussion, I had never heard of such data, or of such a "normal" procedure, or of formal training of such a maneuver. I have run across a good number of "common" practices throughout my aviation career which were not "normal." One particular "common" practice involved moving the thrust reversers to interlock shortly before landing for a "short field" landing. A very experienced and talented pilot scraped a pod and wound up explaining the practice at the end of that long green table. The common procedure was not normal.
Of course, an important distinction between my example and your procedure is the former was not an approved procedure. I take it from your posts that you are describing a manufacturer and company approved procedure.
Since my curiosity is piqued, let me pile on a couple more questions. You described data that assumes an aimpoint and then a touchdown at 1,000' (no flare) and you said the mains touchdown at 650'. Do you really NOT flare, or do you flare and touchdown beyond the 650' point? IF so, how far?
A typical glideslope provides a threshold crossing height in the neighborhood of 50'. (We require a minimum TCH of 47' for an autoland.) Your described procedure stipulates a TCH of 25', roughly half that normal height. How much of that do you suppose might be consumed by a deviation due to a wind gust, or simply a change in winds, in direction or velocity, due to local terrain features?
You described in an earlier post the requirement to annually demonstrate proficiency in a visual landing maneuver without the aid of electronic or visual glideslope aids. Except for the requirement to land 1,000' down the runway, the maneuver sounds like typical Appendix F training. Is the maneuver requirement you described, specifically the requirement to touchdown at the 1,000' point, part of your airline's Ops Specs?
Now... it's coffee time.
