Seggy
Yes. SAY IT!![]()
No.
Our 737s don't have HUDs but Southwest's do. It is called aircraft delivery options....
Yes. SAY IT!![]()
At the end of the day, outside of the checkride environment, if failure or smoking, fiery death is 5 knots, you're doing aviation wrong.
I skipped ahead through like twelve forum pages... but you guys do know what Vef is, right?
For Prop aircraft with critical engines
There's a few prop twins flying around that don't have critical engines (and obviously jets), but the way V1 is written (quoting FAR 1): means the maximum speed in the takeoff at which the pilot must take the first action (e.g., apply brakes, reduce thrust, deploy speed brakes) to stop the airplane within the accelerate-stop distance. V1 also means the minimum speed in the takeoff, following a failure of the critical engine at VEF, at which the pilot can continue the takeoff and achieve the required height above the takeoff surface within the takeoff distance.
I would think that for the purpose of V1 calculations, any engine on a jet is assumed the critical engine unless there's something more specific written somewhere else like part 25? If what I suspect is in fact the case, then calling V1 five knots early and having an engine tank before reaching the true V1 could leave you in a hole you don't want to be in should you attempt the climbout.
Has anyone said otherwise?![]()
Critical engine applies to prop multi-engine aircraft that don't have counter rotating props. On most US non-counter rotating twins the left engine the critical engine due the P factor on the right engine. If on a 4 engine prop aircraft it would the outboard left engine would be the critical engine as it's failure most adversely affects aircraft performance.
I know the "by the book" definition. But why would the FAA not factor in reaction time for a transport category airliner while they would for a Baron?
Remember the FAA has different rules by airplane for each operator.
if they remembered to it probably came something like this "ohmygod ohmygodohmygod AHHHHHHH V onwurblegurble"
When do you think these guys called V1?
Insert "its ok to call it early at X airline, their pilots are a little slow" joke here.![]()
I want to see the video of him landing
