queeno
Ward of the Guberment
My brain just imploded.
Hay Kudos for ever one staying on track on this thread with out the usual thread creep of ...tastes great less filling
Yeah... I'm not sure what he's getting at. If company poi approves V1 instead of V1-5 as Boeing recommends that's what you do.I always thought that technique was the personalized/company-centric method in which you accomplish a procedure.
Actually that does look interesting, although I don't see an option for digital delivery available.View attachment 29418
Bedtime reading anyone?
I'm going to look for something similar and equally authoritative; I'm curious.I have it handy on the shelf for a reason. Always thought one should intimately understand what your performance means in reality.
I understand an eBook is in development for it. It was mentioned by the publisher on PPRuNe a while back.
thank you and this was my point (not so eloquently stated) that in an engine failure scenario, that the performance isn't guaranteed if take off is continued.When the takeoff performance in the AFM is produced, it assumes an engine failure or event one-second before V1. In a runway limited situation, this means the airplane reaches a height of 35 feet over the end of the runway if the decision is to continue the takeoff.
Within reasonable limits, even if the engine failure occurs earlier than the assumed one second before V1, a decision to continue the takeoff will mean that the airplane is lower than 35 feet at the end of the runway, but it is still flying. For example, if the engine fails 2 seconds before V1 and the decision is made to go, the airplane will reach a height of 15 to 20 feet at the end of the runway.
It is also worth noting that these issues are particularly critical on a wet runway. In the engine failure case on a wet runway, the screen height is only 15ft, and although you are guaranteed to be at V2 by 35ft, there is no assurance how far past DER you will be by then. Wet performance limits runways are much more marginal than you might think.
Procedure = mandatory technique.
Again, language semantics, and I find it very difficult to believe you don't understand what we're all talking about.
They do. Putting the gear down before landing is a *procedure*...or, should I say, a mandatory technique that the manufacturer decided would be a good idea.
The Boeing manual feels it is 'best' to call V1 really at V1-5.
#belikeBobDDuckThis is Airbus's explanation of FAA and JAR Part 25 certification requirements. Probably one of the most useful aviation documents I've read.
http://www.smartcockpit.com/aircraft-ressources/Getting_to_Grips_With_Aircraft_Performance.html
#belikeBobDDuck
