doug, why did you bust your mel-ia checkride?
After liftoff, I retracted the gear, departed via the "training" SID in Prescott, climbed up and held on a DME/Radial fix, shot the single-engine DME Arc to a VOR approach, selected gear down at the VOR, the gear didn't come down.
Checked the breakers, voila! One of the breakers is out. I move to pop it back in and he's got the old CFI stranglehold simulating that the breaker 're tripped'.
Ack! Lemme think, single-engine in a Piper Seminole, it's july and about 95 degrees, single engine rate of climb is about -80 fpm as per my calculations... Screw it, manually extend the landing gear and land this beast else we're dead. I did a quick memorized flow on manual landing gear extension and nothing. No lights.
Can't get the gear down, the manual/emergency extension doesn't work and in the best case scenario, we're going to be a smoking hole during the missed approach.
About .5 from the missed approach. Can't get the gear down because he's electrically failed the motor and the manual extension didn't give me lights at all, not even a gear unsafe light.
I use some 'executive authority', look outside and see that my nosegear is fully extended, decide that in these conditions, especially simulated IFR that this is going to be a one-way because there's no way to conduct a successful missed approach.
He gave the other engine back at this point and the instructor asks tower for a left downwind for a full stop and I thought I aced the checkride because I kicked but on the instrument takeoff, did well in the single engine DME Arc and hit all of the points on the VOR approach.
Then we land and he tells me that I've failed because when I selected "gear up", he had pulled the breaker on the landing gear motor and the breaker for the lights (or something like that) and started preaching about watching for the ammeter spike during gear retraction.
"Sir, the ammeter did spike during retraction"
"Uhh," he answered, "maybe it did because I didn't pull the breaker fast enough, but you should have lifted the hood and looked outside at the nacelle mirror to see if the nose gear went up."
"As far as I know, I'm not allowed the lift the hood during a checkride until instructed to do so. Specifically which part of the takeoff, holding, single-engine ARC, single-engine VOR approach wasn't within limits?"
"Well, you failed right there with the gear malfunction during takeoff"
And then ensues the big speech about how us Riddle students trounce around the airport acting like we own the place and how I'm supposed to take my experience back to my training manager and show him (actually a "her") that we weren't as good as we think we are, yadda yadda yadda.
"Sir, I'm just here for a checkride."
"So lets go ahead and schedule your retest for next week and it's only $x."
"Afraid not, have a nice day."
And then my instructor got me set up with a different DPE and things went just fine.
A thing against DPE that fail students for idiotic things such as having the nav lights on during engine start? You bet!
