Thanks for all of the insight on this topic, It seems there is a lot of speculation. I will take all your info and try to put it all together. Hopefully I don't get asked this on my FAA checkride lol. Thanks again.
I useually stick with the simple Bernoulli/Newton 70/30 explination for primary students. It's basic, easy to understand, and really all a primary student needs to know.
If you are referring to Newton's 3rd law of motion...leave that out. It really has no effect on lift until very high speed, high altitude flight.
Newton's third law of motion, as its law moniker suggests, is an integral part of Newtonian physics and has everything to do with lift
Lift is NOT the result of the difference of pressure between the top and bottom of the wing. For that pressure difference ALONE to keep a Cessna 172 airborne- it would have to be travelling at 400 kts.
This is a terrible book. Easy to understand, yes, but just because something is easy to understand doesn't make it right. Their fundamental theories are at odds with the aerodynamics of the past 100 years. There is no evidence that the Coanda Effect has any role in lift production. You won't find it mentioned in any other aerodynamics book, except in exotic applications like vectored thrust.HIGHLY recommend the book "Understanding Flight"
The second part. You can't see circulation, because the air doesn't actually flow in the direction that circulation says. That's because the circulation is superimposed over the relative wind. The net result of circulation is that the air over the top of the wing is faster and the air below the wing is slower. This is exactly what you would expect if circulation were real.Does that make any sense or do I have absolutely no clue what circulation is?
I HIGHLY recommend the book "Understanding Flight" by David Anderson and Scott Eberhardt (an aerodynamicist at the UW) that is where I learned all of this.
Here's a 14 page teaser from them http://home.comcast.net/~clipper-108/lift.htm
Very interesting! Let me know what you think of it.
[/url]
Newton's third law of motion, as its law moniker suggests, is an integral part of Newtonian physics and has everything to do with lift at all speeds (well, when much less than the speed of light ). The third law states that particles experience equal, opposite, and simultaneous reactions. This is nothing but a statement of conservation of momentum. Conservation of momentum generates three equations for each component of space, and these are what are solved fluid mechanics problems in addition to the conservation of mass-energy.
Newton's laws are correct for most aeronautical engineering purposes. In his time Newton applied his laws to fluid dynamics through a simple fluid model (sine squared law), and it is that model which is flawed except at high speed, high altitude (hypersonic) flight.
For more information see "A History of Aerodynamics" by John D. Anderson, Jr.
Lift is an equal and opposite reaction to the huge mass of air being accelerated downward off the trailing edge in the form of downwash.
[/url]
This is simply wrong. The wrongness of it can be made obvious in the fact that any force applied to a wing flying through the air only has one mechanism for its transmission.....pressure. Even if you want to model lift as deflecting an air mass downwards, the wing has to apply this force to the air somehow. How does a wing grab a hold of the air and throw it down? Pressure. There is no other way.
One of the most fundamental ideas of aerodynamics is that you can take the sum up the pressure difference around an airfoil and calculate lift directly. The main problem has always been calculating the pressure any any particular point. You will find formulas in all advanced aerodynamics books describing this.
There are a number of real effects that demonstrate that circulation is real. There is a starting vortex created every time lift changes. And, as you mentioned, the trailing vortices. And slow motion photography can show the circulation getting started. Realm09 had some interesting MIT videos about that. I'll see if I can find the link.
I think it's important for anyone understanding how lift if created (or explaining especially at the CFI level) to understand that lift is not created by downwash. Yes, downwash is a byproduct of lift...and the magnitude of the downwash vector is indicative of that of lift creation...but it is not the reason lift is produced.
*****It's also important to understand that lift is not produced by air deflecting off the bottom of the wing (commonly called Newton's 3rd law).*****
To be concise, simple and correct see how TG summed up one of his posts....1) Law of Conservation of Matter, 2) Bernoulli's Principle and 3) Circulation. If you have questions on any of those ingredients, I'm sure he'd be happy to expand.
Well I would have never EVER imagined that a book written by two aerodynamicists with access to wind tunnels would be wrong!!! I'm very surprised! I'd like to take to position that they have THEIR foot in THEIR mouth- not me (God forbid!)!
One thing to keep in mind is that no matter how well established a scientific topic is, you will find one or two people with good credentials who dispute it. You will find one or two PhD's who dispute Einstein's theory of relativity or Quantum Mechanics or Evolution or the age of the Earth or that germs cause disease, etc.
If these people actually had data that supported their point of view and was not explainable by the conventional theories, they might revolutionize the science. This occurs sometimes, but this hasn't occurred by Andersen and Eberhardt. The world yawned. And note the book was not published by a reputable scientific publisher.
One interesting thing is that this book of theirs originated with an article they wrote in the EAA magazine. They presented their theory in a much abbreviated fashion, but what was interesting is that they really didn't claim their theory was correct, but was easier to understand. They shot down the Bernoulli theory of lift, but they did so by constructing a straw man. In other words, they criticized the "hump theory" of lift, which is a misrepresentation of the conventional theory anyway. And claimed that conventional theory could not explain invented flight, which is false.
Their article was very popular, which is probably why they wrote the book. Perhaps they wanted to see how far they could take their own reinterpretation or perhaps they just wanted to make money?
I'm going to give you a link to a newsgroup thread. There are two significant participants: John Denker and John Lowry, both physicists. Lowry has written a book on aerodynamics which is very conventional. Denker has an online book which is also conventional and he addresses the Coanda stuff. He also has links to sections of his book which might be useful. Here's the link:
http://groups.google.com/group/sci....lowry+"understanding+flight"#49a63f42514668b6
The original poster is totally confused
There are a couple of problems with this. First, scientists have long modeled the air flow around the wing; in the early days, they lacked some of the sophisticated theory we have today and had to make some simplifying assumptions. One that they made is this: air has no viscosity. This is referred to as the "inviscid theory" and the interesting this is, the air still manages to navigate around the airfoil, no viscosity necessary.the viscosity of the air (faster air "falling over" slower air at the wing surface) results in the Coanda effect, which causes the air to follow the upper surface of the wing and then depart the trailing edge continuing downward at that angle as downwash.
Couple of things here. First, what causes an acceleration? According to Newton, F = ma, so a = F/m. In other words, an acceleration requires a force. If the air is being accelerated, there is already a force acting on the air. But how can a force already exist prior to the air moving when we're trying to explain the existence of that force by the moving air?is the cause of the accelerated air that becomes downwash.
I'm not sure of the validity of that statement. Air does have *some* viscosity and so must support *some* tension. Also, a length of yarn could support *some* compression, just not much.Denker said...That is totally impossible because air does not support tension forces (just as a length of yarn does not support compression, or "push").
I love this subject! "How lift works" is extremely interesting.
First, no one should take this personal, because it is not...
you are correct. I remember reading someone mentioning the 70/30 rule above. Aircraft lift is not entirely based off of a low pressure envolope on the top of the wing. It is a combination of several factors, mainly the bernoulli equation then, to a much lessor degree, newtons laws dealing with the molecules striking the surface of the wings and creating a "cushion" of air for the wings to skim across. Now for those that say that the Newtonian theory is the predominant reason for flight they have not spent that much effort learning about aerodynamics. Boundary layer aerodynamics limit how much impact Newton can have on the lifting capacity of wings.
Downwash is just the result of the accelerated airflow (decrease the pressure, the velocity increases) off the wing, the fact that is travels downward is associate with the angle of attack that that wing is traveling at. This is where Newton's Laws come into play.
There IS extremely low pressure above the wing and the pressure below the wing, in comparison, could be considered high, but this pressure differential is not keeping 870,000lbs of 747 airborne. The accelerated airflow above the wing results in very low pressure which creates a vaccum like a big scoop above the wing sucking in tons and tons of air from above and diverting it downward as downwash.
The typical wing surface area of a 747-400 is around 5650 sq.ft. that comes out to be 813600 sq inches. Pressure differentials can be measured in psi. so the wing loading comes out to be about 1.069 pounds per square inches. so if the pressure differential is even less than 2 psi, the airplane will fly.
An aerobatic airplane can fly upside down so a wing can lift even with "backwards" camber- all you need is an angle of attack to create a pressure differential that sucks in air and shoots downward as downwash.
Aerobatic aircraft are a whole different set of rules, they have wings that have the same camber on the tops as the bottom and rely heavily on the angle of attack of the wing and Newtons laws to maintain flight. Acrobatic planes typically need either a higher wing surface area ratio, or a faster more pawerful engine to overcome the decreased dependence on bernoulli and increased dependence on Newton.
There are tons of pictures on airliners.net that confirm the existence of downwash. Just search for "condensation" or "contrails". I have all the good ones on my hardrive, but I don't have links to all of them on the website to post here.
Contrails, are a very know reality of flight. however there are two types of contrails. High Altitude Exhaust Contrails, and the type I think you are actually talking about, Wingtip vortice contrails. Contrail form in the low pressure center of the wingtip vortices off the end of the wings. for avery similar reason that Fog forms in a 2-liter bottle when you open the cap.
To be clear, I am never posting to try to be "right" but to have an interesting discussion.
I just changed my avatar- check out the downwash and the low pressure "scoop" above the wing scooping in and diverting tons of air downward for the equal and opposite reaction!
Regarding circulation- I don't want to say that I disagree with it (mostly because I'm not very familiar with it- certainly not enough to give an OPINION on whether I think it is right or wrong), but my suspicion is that circulation is simply describing the low pressure above the wing propagating forward up to and over the leading edge of the wing and sucking some of the high pressure from below the leading edge. And also describing downwash of course.
Not sure about ciculation either. Most of the applications for Circulation aerodynamics is reserved for the Automotive industry, particularly Formula 1 cars, and Sports (baseball - Curveballs, changeup, etc.) I haven't studying the applications for aerospace applications yet.
I would be VERY interested to see a photo illustrating circulation in action.
That is why I am so convinced of downwash- because of proof that is clearly seen in pictures like my avatar picture.
Thoughts, comments, rude remarks?
I just made this photo album on airliners.net full of the best condensation/downwash pics on the site...
http://www.airliners.net/search/photo.search?album=16683
