DPApilot
GUYSH! GUYSH! GUYSH!
:yeahthat:Ask them how they're getting to the runway below DH. Unless you're doing an autoland, any approach, even an ILS, is just something to get you close enough to be able to do a visual maneuver.
Over here, it is company policy to back up ALL visual approaches with an ILS (if it's available). If you are using an ILS you must follow the glideslope until inside the middle marker. At that point you are free to deviate to land. HOWEVER... our POI thinks differently, and with her in the jumpseat you follow the glideslope to the ground.
When did pilots stop trying to land visually?
If we have a PAPI/VASI, awesome. If we have a G/S, awesome. I find there are a few times we have neither, and many times it creates problems. That concerns me. We should be able to visually fly an approach to a runway regardless of the type airplane we are flying. That is why I always brief a few things:
Jtrain, do you remember the approach we did into DCA? I believe it was the Mount Vernon Visual circle-to-land runway 33. How much did we use the glideslope or VASI? Here is a hint: There is no visual vertical guidance for runway 1 in DCA. Also, our company procedures require that the flying pilot does NOT have the ILS runway 1 tuned when doing the Mount Vernon visual. So what do you use for vertical guidance at night, just like we did yesterday?
- Runway Length
- Runway Width (especially important in Canada)
- Touchdown Zone Elevation
My point is that not every runway we arrive into will have a VASI or glideslope. While we should try to use the resources we have available to us, the most important thing is using our eyes to ensure we are at a safe distance above all obstacles, and that we land in the touchdown zone.
Yeah, but good luck finding any 121 airline with Ops Specs allowing non-stabilized approaches for turboprops.Interesting, FAAO 8900.1 4-221 says
Turboprops are free to do whatever they want, wooo!anic: (I know, this is about visual approaches. I just thought the distinction was unusual.)
A PAPI is a specific type of Visual Approach Slope Indicator. At least that's my understanding. VASI is used in the regs as a generic term for all visual systems, IIRC.The regulation makes no mention of a "Precision Approach Path Indicator", just "Visual Approach Slope Indicator". Is the reg intended to separate the two?
-mini
Any of you guys that have flown the ILS to 23 into CLT know about this issue. I'm sure other airports have the same problem but I can't think of any off the top of my head.
You are on GS and on the PAPI's until about a 1/2 mile final. Then if you transition to pure visual and follow the PAPI's you get the the AFCS yelling at you "Glideslope! Glideslope!". I'd love to know what's the legal solution here...I've been told when operating 121 one cannot go below GS even when on a visual approach yet I have been unable to find anything in the FAR's that addresses this particualr situation.
Anyone know for sure?
One word of caution, however. If you are flying a bigger airplane...make sure you study gear heights at the threshold. You will be surprised how low the gear will be and how far behind the cockpit they are. On the glideslope...when the cockpit is 50' over the threshold...the main gear might cross at only 23' or so. Fly one or two dots below G/S...and you may be in danger of not having the gear make it to the pavement!!
In the 767, I never fly below G/S for this reason.
B767Driver -
I recall reading that the threshold crossing height is based on where the glideslope antenna on the airplane would be if the airplane was on glideslope at the TCH. In other words, if the antenna is around the main gear then perhaps the wheels are another 3-10 feet below depending on airplane type.
Does this conflict with your information?
I got a question for everyone? I was flying with a captain this past week, and he was flying all his approaches with the PAPI at 3 red and 1 white. When I noticed the 3 reds, I stated "I see three red one white". He responded with "correct on slope". After we made it back to the gate, I asked him why he was flying 3 red/1 white. His answer was that its the correct way to fly the PAPI in our aircraft.
Now I have not read this anywhere, That I recall. I do remember so stuff about high cockpit aircraft flying the upper slope on a VGSI or 3 white/1 red. But thats for something like a 747, not a EMB-145 right??
