Now, for the next question...when approaching a class g airport with an operating control tower, are the procedures the same as class D? (Yes, class g towered fields do exist.)
(And yes, I do know the answer, I'm just throwing it out there for the OP)
Yes, I am familiar with regulations. I hope this is what you were looking for.
Sec. 91.126 - Operating on or in the vicinity of an airport in Class G airspace.
(a)
General. Unless otherwise authorized or required, each person operating an aircraft on or in the vicinity of an airport in a Class G airspace area must comply with the requirements of this section.
(b)
Direction of turns. When approaching to land at an airport without an operating control tower in Class G airspace --
(1) Each pilot of an airplane must make all turns of that airplane to the left unless the airport displays approved light signals or visual markings indicating that turns should be made to the right, in which case the pilot must make all turns to the right; and
(2) Each pilot of a helicopter must avoid the flow of fixed-wing aircraft.
(c)
Flap settings. Except when necessary for training or certification, the pilot in command of a civil turbojet-powered aircraft must use, as a final flap setting, the minimum certificated landing flap setting set forth in the approved performance information in the Airplane Flight Manual for the applicable conditions. However, each pilot in command has the final authority and responsibility for the safe operation of the pilot's airplane, and may use a different flap setting for that airplane if the pilot determines that it is necessary in the interest of safety. (d)
Communications with control towers. Unless otherwise authorized or required by ATC, no person may operate an aircraft to, from, through, or on an airport having an operational control tower unless two-way radio communications are maintained between that aircraft and the control tower. Communications must be established prior to 4 nautical miles from the airport, up to and including 2,500 feet AGL. However, if the aircraft radio fails in flight, the pilot in command may operate that aircraft and land if weather conditions are at or above basic VFR weather minimums, visual contact with the tower is maintained, and a clearance to land is received. If the aircraft radio fails while in flight under IFR, the pilot must comply with
§91.185.
