I'm just not a fan of unrestricted GA.
I am a total fan of unrestricted GA.
Here's what I propose as a trade off to fund the ATC system.
Allow the airlines to schedule all the flights into any airport they want under the following rules:
1) The maximum total number of 121 operations into the airport is restricted by the maximum operations per hour of the least efficient runway configuration at the lowest available weather minimums for that airport.
2) For each flight scheduled on top of the above, up to the maximum number of operations allowable for the optimum runway configurations in optimum weather, the first operation will be charged a $10,000 operation premium, and a 5% increase for each operation beyond that raising the fee for each. For the purposes of this an "operation" will be a landing followed by a takeoff on the same day.
3) For each operation scheduled beyond the maximum operation as stated above, the first operation will be $50,000 increased by 5% for each subsequent operation. Again, the same definition for "operation" shall apply.
4) For delays caused by operations under rules 2 or 3, a $1,000/min penalty will be assigned.
5) Airlines that currently use the airport as a "hub operation" will retain that right and assigned the current percentage of usage for that airport. Remaining slots will be equally distributed among air carriers desiring use of the airport.
a) As an example, if Delta makes up 80% of the operations for ATL and AirTran uses 10%, then the remaining 5% will be distributed among the other air carrier. Foreign Air Carriers are exempt, but the operations will be counted in the airport's total.
b) Using a) as an example, if the total number of operations exceed the number specified in paragraph 1, a "snap shot" will be taken of all
scheduled operations to that airport from June 10th, 2007 for the "summer schedules" and November 22, 2007 for the "winter schedules". Then the percentages will locked in at that point.
1) Air Carriers wishing to renounce a hub, will do so in writing, giving 90 days notice. Such notice may not be rescinded, and the percentages will be re-adjusted, first right of refusal for slots will be to another incumbent hub aircarrier. If that air carrier declines, or there is only one "hub air carrier" in the airport, all the slots will be equally divided among the other air carriers.
2) Any Air Carrier wishing to utilize Rule 2 or 3 will do so in writing, with a minimum of 120 days notice. Understanding that forecasted schedules are proprietary and competitive information, the information will not be made public. However, on the first day that the service is to begin, the fines will be enacted with no "trial period" as to avoid "Gaming the system"
c) For purposes of this distribution, "Air Carrier" will include all operations of a "Brand" e.g. American slots in ATL would encompass any and all operations of American, American Eagle or American Connection, or any other d.b.a situation for American. If an independent carrier, such as Horizon, has a code-sharing agreement, where the American name is not used, and marketing is not conducted by AMR, or any subsidary, then Horizon will not be penalized for the codeshare.
I think that'd clean up alot of the mess.
