Or any other kind of pilot for that matter.How do you know when a fighter pilot walks into the room? He will tell you.
131 degrees is "almost belly up"?
It is for a 737. Way more "almost" than you really want to get in an airplane that probably has a less than 3g limit!
Didn't a B-727 crew do this once? They were manually extending leading edge slats part-way (the "Boeing manuver" I recall), when the engineer failed to pull both breakers simultaneously. One set of slats fully extended causing that wing to stall, rolling the aircraft over and beginning a high speed, spinning descent. The crew was doing everything to recover on the way down including extending landing gear and flaps, and they recovered around 10,000'. They erased the CVR at the gate, and their careers with it.
I'm back in the 757 sim in a couple weeks for recurrent. While not a 737, I'd imagine things are pretty similar; I'll try the Amazing Tumbling Boeing trick.![]()
I don't buy it. Rudder trim? Really? I think he kicked the rudder not the trim.
When I wanted to roll the B-300 sim at FlightSafety, the instructors freaked out and implied that since there was no flight data modeled for flight outside those roll parameters that the sim would go bonkers.
When I worked at the Museum of Flight up in Seattle in the late 80s/early 90s, Boeing test pilot Lew Wallick gave a presentation in which he coyly said that each model of Boeing airliner at that time had been over on it's back at some point during the flight test. So...perhaps Boeing sims actually have that data modeled!
There's a hell of a lot that you can do with an airplane well within 3Gs.
Still, to this day, airplanes have yet to figure out which way is 'up'.
That's true... and tex johnson may have barrel rolled a 707, but I don't want to try it on a large aircraft. Fun in the sim, though!
It's more properly referred to as going to coffin corner. Pull LE FLAP CONTROL cb on aft circuit breaker panel, put flap handle in 2 = more wing area, no LEDs.Didn't a B-727 crew do this once? They were manually extending leading edge slats part-way (the "Boeing manuver" I recall), when the engineer failed to pull both breakers simultaneously. One set of slats fully extended causing that wing to stall, rolling the aircraft over and beginning a high speed, spinning descent. The crew was doing everything to recover on the way down including extending landing gear and flaps, and they recovered around 10,000'. They erased the CVR at the gate, and their careers with it.
I have a fuzzy memory of a Desert Storm-era story of a KC-135 crew rolling it, and causing at least one of the engines to come off the wing. Anyone else remember that, or have I just been smoking too much peyote?
