All Nippon 737 roll to 131.7 degrees
It is for a 737. Way more "almost" than you really want to get in an airplane that probably has a less than 3g limit!
There's a hell of a lot that you can do with an airplane well within 3Gs.
Still, to this day, airplanes have yet to figure out which way is 'up'.
Didn't a B-727 crew do this once? They were manually extending leading edge slats part-way (the "Boeing manuver" I recall), when the engineer failed to pull both breakers simultaneously. One set of slats fully extended causing that wing to stall, rolling the aircraft over and beginning a high speed, spinning descent. The crew was doing everything to recover on the way down including extending landing gear and flaps, and they recovered around 10,000'. They erased the CVR at the gate, and their careers with it.
I'm back in the 757 sim in a couple weeks for recurrent. While not a 737, I'd imagine things are pretty similar; I'll try the Amazing Tumbling Boeing trick. :)
TWA 841, 1979. Hoot Gibson pilot. Not to to be confused with the same flight number in 1974 that was a 707.
When I wanted to roll the B-300 sim at FlightSafety, the instructors freaked out and implied that since there was no flight data modeled for flight outside those roll parameters that the sim would go bonkers.
When I worked at the Museum of Flight up in Seattle in the late 80s/early 90s, Boeing test pilot Lew Wallick gave a presentation in which he coyly said that each model of Boeing airliner at that time had been over on it's back at some point during the flight test. So...perhaps Boeing sims actually have that data modeled!
They just didn't want you to do it. I've done barrel rolls in the KC135 sim and the Saab sim. Haven't tried to do it in the Q sim yet. Perhaps next week if we have time left over...
I have a Strategy for this in the sim. When they give you an aileron trim runaway, just pretend you're a little slow on the uptake and tell them you felt it was "safer" to take it all the way around rather than fight it in knife-edge flight. Works good, lasts long time.
I've had instructors put both the 757 and 767 sims upside down on me during unusual attitude recoveries. The 757 does fine, but the 767 does NOT like being on its back. Lots of dramatics and altitude loss to get it flipped back over. :)
That's true... and tex johnson may have barrel rolled a 707, but I don't want to try it on a large aircraft. Fun in the sim, though!
I have a fuzzy memory of a Desert Storm-era story of a KC-135 crew rolling it, and causing at least one of the engines to come off the wing. Anyone else remember that, or have I just been smoking too much peyote?
It's more properly referred to as going to coffin corner. Pull LE FLAP CONTROL cb on aft circuit breaker panel, put flap handle in 2 = more wing area, no LEDs.
Naturally, trailing edge flap extension at that altitude does "interesting" things to the aerodynamics. As Hoot and friends found out.
Kansas National Guard 190th ARW.
You're clear to keep up the peyote. :)
