You are correct. But here's a quote from one of the Chief pilots of our company
" You aren't on duty sitting at home watching Opera when your reserve starts! "
Which is true, you aren't on duty. BUT, for duty time limitations (and this is a contractual thing I believe) the beginning of your reserve time counts towards your duty day limitation. They can only fly you 4 hours past your end reserve time.
Duty starts when you show up to work.
You need to know this, otherwise one day you're going to accept an illegal flight assignment and your certificates will be suspended.
Your company has said sitting at home on reserve is not duty, and the FAA doesn't care if it's duty or not. The FAA however is proof positive certain that sitting at home on reserve is NOT rest. This is not a "contractual thing", it's an FAA thing. There is no such thing as a "duty day limitation" as far as the FAA is concerned.
It's all about lookback rest and the ability to find the required rest. So if your reserve time is 12 hours, then you cannot fly past 4 hours after the end of that reserve time because you will not be able to lookback and find the required reduced rest of 8 hours. That's where the commonly held misconception about the "16 hour duty limitation" comes from.
However - let us say that on Day 1 you fly a lot (8 hours) AND on Day 2 you are scheduled for a 1.5 hour flight first thing. To accept the 1.5 hour flight, given that you are scheduled for > 9 hours of flying in 24 hours you must receive at least reduced rest of 9 hours between Day 1 and Day 2. You receive that rest and no more (well technically you can have 10:59 or rest and it's still reduced rest because you didn't get the required rest). After the 1.5 hour flight you are on reserve.
When must you be done on Day 2? You must be finished *15* hours (and more you must be dutied off, not just not flying) after you dutied on, because you are required to get 12 hours of compensatory rest that must start no later than 24 hours after the start of your reduced rest. So if you're living and dieing by the 16 hour duty day and you accept an assignment into that 16th hour, well that's an illegal flight.
You need to know this stuff, because the company may not assign and YOU MAY NOT ACCEPT an illegal schedule. Don't dismiss FAA regulations as "a contractual thing" because if you do the FAA may dismiss you as "no longer a pilot".
And finally - who sits at home on reserve watching Opera????
