Alaska Hawaiian Merger
Airliners and HUDs. šŸ˜‚. As if airliners are in some 60 degree dive bomb pass, or in some offensive knife fight air to air, where there isn’t even one second to take a look down at the panel and scan something lest disaster occur…..
As I've already mentioned along with others it's not required on the 700. Just the abominations that were made bigger since you can drag the tail on the ground, somehow.
Is it that difficult to rotate to a particular pitch angle and lift off without continuing to increase pitch and striking the tail on a -900 prior to lift off? Mine is very short body, and I still do it that way: not do this continuous rotation that I see some pilots do until the plane lifts off.
No it's not. I've observed one pilot have trouble with it. Once. It's not difficult at all. Welcome to the airline(s)
We have airliners with a HUD AND a FLIR...so there šŸ˜†
United doesn't have them on any 737
Don’t they have 3rd axis for autoland rollouts? Seems like one of the issues with the max was a rollout guidance servo, which didn’t effect us or SWA because we don’t have that.
I'm not opposed to swapping the engine gauges to the PF side if that is what people want. But I'm also not really an N1 reference person. We fly a ton of variants, with greatly differing gross weights. It probably isn't that much mental real estate to memorize a target N1 for each variant at typical landing weight, but I guess I'm just not super great at number remembering like that, nor do I think it really matters. I also come from a place where we don't do any of that, to include computing approach speed (other than trimming on-speed AoA), simply because there are a ton of variables. Tailwind vs headwind dramatically effects your VSI for a 3.0 glideslope for example. We also have very large variations in gross weight at landing that are not entirely predicable, not to mention external configurations that fly differently, hence I think, the lack of what others might perceive as discipline and book knowledge. Gusts are pretty normal at my pilot base/domicile/anywhere north of here, and require some reactive throttle movement outside the range you mention, even outside of true wind shear conditions. I guess that is all to say that my spidey sense for this starts going off anytime I need to make larger throttle movements without having made a corresponding major change in pitch attitude/anything else. Don't really need to reference the N1 gauge for that. Just what my hand is having to do to keep the speed tape in the right place. I'm probably overly simplistic, and maybe even exhibiting bad habits. But that is my take, which at maybe a few hundred hours in type, is super valuable I'm sure :)
Idk, pretty small sample size but all 3 jets I’ve flown your normal N1 on final, configured, should be between 55-60% and doesn’t vary THAT much on weight, wind, or even model. Where it really helps is that situation where you’re hand flying, have the thrust pulled back to slow and configure, and now your IAS is rapidly approaching target as you’re doing the landing check. If you know you can set that ballpark and you you’ll be close it just makes life easier. Also in a former life say you’re setting up the big downwind onto 26 in jnu, you know if you set that ballpark when you roll out on final you’ll be close enough without a lot of mental math or fiddling with avionics or whatever
ā€œSwitching to trailing!ā€
*grindrindrindrindrinPOOOOOOOO*
ā€œKeel em! KEEL em!ā€
Apparently tariffs will affect the aircraft delivery schedule in 2025. The seat manufacturers are Euro based with plants in Mexico.
In case anyone wanted to know the annual hiring black swan for 2025 ahead of time…
Oh also:
