Alaska Hawaiian Merger
I’m not going to knock him on that, I really don’t like the HUD in gusty situations. Too much “dancing” of the cue.
4000+hrs of flying an HUD, and it still is my least fav thing to use the HGS for.
Agree to disagree and it's a requirement for us as PM. I haven't really noticed any "dancing" on our airplane. I don't program it for takeoff 99% of the time, I find it most useful with the EFVS for storm avoidance and for approach for SA as a pilot monitor. It'll be a sad day when i won't have one if i'm forced back to the right seat.
You guys dual HUD?
For us, it’s CA side only. And only required to be used on the -800/900/MAX during takeoff and landings for tailstrike awareness. That’s the (only) official requirement. Of course, it can be MEL’ed/deferred.
With the HUD coupled to an autoland approach, we can take the lowest RVR of 400 for a CATIII approved runway with at least 3/3/3 on the plate.
It's required because of the tailstrike indicator. It's dumb the FO doesn't have one. But it probably saves a lot of money.
It’s definitely helpful as pilot monitoring to see their thrust versus airspeed
as PM I definitely include the N1s in my scan on final. Flew with a lot of FOs coming straight from props at the last gig and because of the different feel to power management on jets it was very common to see new guys oscillate between 35% and 70% N1 without realizing it. I did the same thing when new on the Lear.
The schoolhouse used to emphasize keeping the power stable on approaches. For a 150K 900ER you needed to hold 56% ish
They don’t talk about this anymore…
This was false as of a year ago. Especially with having to do the unreliable airspeed stuff they emphasized knowing your ballpark power settings. At least the instructors I worked with did.
I haven't heard anything about it in a long time. I used to hear about it every briefing. Just goes to show you that everyone's experience is different.
IMO as a CA, when SHTF, I’d rather the engine instruments be in one consistent place all the time.
I have yet to have a FO demand the gauges on his side. Why you looking at engine gauges on landing? As a FO my eyes were on the runway / touchdown area and LOC/GS + airspeed indicator with its trend. That’s all you need to know if you need to add or take away power.
You should go re-read the indications for windshear, and then explain to the class why you’ll now be incorporating the engine indications into your scan.
For the 737, I know for a Flaps 30, I need approx 58-62% N1 (68/69% for a 40). If I’m varying off that by much, that’s getting my spidey senses tingling.
I’m sure AS has it in your FOM/Vol1 or whatever y’all use over there, that “HGS shall be used for windshear conditions”…I know at QX it was.
We built a CQ training scenario where Capt’s, in particular, got into a windshear situation that they would get tunnel vision in the HUD. You’d be so focused on it that you’d not notice being around 70% torque (vs 28-30% for normal).
Bottom line, don’t be a HUD cripple and do an L shaped scan so you keep the engine indications in it.
I'm not opposed to swapping the engine gauges to the PF side if that is what people want. But I'm also not really an N1 reference person. We fly a ton of variants, with greatly differing gross weights. It probably isn't that much mental real estate to memorize a target N1 for each variant at typical landing weight, but I guess I'm just not super great at number remembering like that, nor do I think it really matters. I also come from a place where we don't do any of that, to include computing approach speed (other than trimming on-speed AoA), simply because there are a ton of variables. Tailwind vs headwind dramatically effects your VSI for a 3.0 glideslope for example. We also have very large variations in gross weight at landing that are not entirely predicable, not to mention external configurations that fly differently, hence I think, the lack of what others might perceive as discipline and book knowledge. Gusts are pretty normal at my pilot base/domicile/anywhere north of here, and require some reactive throttle movement outside the range you mention, even outside of true wind shear conditions. I guess that is all to say that my spidey sense for this starts going off anytime I need to make larger throttle movements without having made a corresponding major change in pitch attitude/anything else. Don't really need to reference the N1 gauge for that. Just what my hand is having to do to keep the speed tape in the right place. I'm probably overly simplistic, and maybe even exhibiting bad habits. But that is my take, which at maybe a few hundred hours in type, is super valuable I'm sure :)
100% agree, but I also wonder why the f some people are so (apparently) aggressive with their rotation? IMO, if you were to, let's just suppose, push with erroneous numbers, general experience flying airplanes should prevent one from blindly continuing that 2-3 deg/sec rate when the airplane isn't doing the normal things and banging the tail before you realize it. I'm sure the training dept doesn't like it, but just like every other airplane I've flown, I do a mini rotation, wait for the wheels to get light and to feel the wing actually flying, and then I re-apply that rotation/pull. If my Vr was 20 knots slow, I would delay that second rotation until I felt the wing flying, just out of habit, and not bang the tail I don't think. To hell with the TERPS/second segment numbers at that point. Granted I've had like one rotation in my whole time flying this hog, where it just did its own thing, uncommanded, probably a gust of some sort, and I had to apply forward pressure to stop it, while the CA just assumed I'd f'd it up. But that isn't what we are really talking about with tail strikes I don't think. And it was easily fixed well before that happened, in my case.
Exactly all this!
I've only seen it once at ATL. It's always a combination of factors. The runway has some pretty noticeable grade changes. Right when we started going uphill it was time to rotate and the guy really yoinked one the yoke. Tailstrike indicator was moving rapidly toward the little airplane and my hands came up to push forward on the yoke.
Not fun.
Airliners and HUDs. 😂. As if airliners are in some 60 degree dive bomb pass, or in some offensive knife fight air to air, where there isn’t even one second to take a look down at the panel and scan something lest disaster occur…..
